Tampakayaker said:And this will get rid of the dreaded fine threaded screw on ring, that seems to take as much time to securely screw on as setting up the rest of the camp!
https://www.amazon.com/dp/B07BDY3KZJ/?coliid=I27161YWBEV0XW&colid=125JQV28Y904S&psc=1&ref_=lv_ov_lig_dp_it
This replacement ring has been posted on other threads about power problems.
This is an Amazon review
This ring replaces the standard screw on ring used to make an RV shore power cord connection weather tight. The difference is that this does not require matching the threads, which invariably get cross threaded and damaged at worst, or is so frustrating that the ring isn't tightened at all, a very poor practice. As long as the receiving male portion has the necessary slots in it, all this requires is about 1/8th turn to lock into place. It's a bit of a pain to remove the old ring and replace it with this one--a little dish washing soap would make it easier, but still not easy. But it's well worth it.
Snohomish WA, 2024 3.6L Grand Cherokee
managed by VE Smart Network
I scratched my head a bit on that as well. The ring discussed here is the one on the power cord.DesertDweller said:I must be dense, but does this item replace the ring on the power cable or on the receptacle on the T@B? Sorry if the answer is obvious.
@Denny16...I just went and un-hooked my power cord and as you mention, there are two slots cut into the threaded portion of the outlet.Denny16 said:Yes they are Chris, I also,am getting the new ring. If you look at the 30-amp connection on TaB, you will see a slot cut into the threads at 9 and 3 O’Clock positions, this is the slot referred to, and our 2018 TaB400 has the slots, so I would bet most TaBs do have the same connectors.
Tabaz said:With wonder and abandon, I purchased this item in a heartbeat of its post. Boiled a tub of water to soften the plug. Old, useless ring removed with dispatch. New ring forced into position without complaint. But alas, can not get the new ring to sync with the 3 and 9 o’clock tabs on my 2016 T@B. Yes, I pushed the plug into the receptacle (heretofore called the Female End). Suggestions?
I guess living in the Sunshine State has some advantages with the heat. My cord is stored in a black diamond plate steel box. I got my ring today, gave a slight push on the old ring and rolled it right off the plug. The new one went on even easier.DenisP said:@ChanW Thank you for this post. The new ring arrived today, I immediately did the hot water install and drove to my 2018 400 in storage and the cable fit perfectly. I will not miss the threading process.Thanks again.
