Ok, so I had what I thought was a brilliant idea for mounting solar to the roof. I like the flexible permanent panels, but then you've got to be parked in a way that is conducive to the sun angle. The portable ones fix that, but I don't love the idea of having to store them inside. What about if I attach a solid panel to the roof with a full motion flat TV mount. That way it can swivel, tilt, etc to the correct angle.... Stupid, or brilliant ?
                0 ·
Mine are mounted to the roof for several years and I have two aspects for you to consider:
1. Try not to chase the sun. Unless you enjoy moving solar panels around while camping, the objective should be to set it and forget it. Depending on your location and season, it may or may not be even necessary to move. Again I speak from experience, not theory. In sunny clear skies in summer, you may have all the energy you need. In the dark rainy winter it won’t matter what angle you mount at. There is no one solution. But Solar Bob once told me never chase the sun, buy more panels, adjust usage, buy better batteries - but dont chase the sun. For a particular site and season, I either leave mine in travel position or raise to horizontal.
2. Wind. I have been in some really windy conditions, often after dark, in places with limited cell service, that came up without warning. You have to be sure (I did the math calcs) that your mounting will withstand strong (maybe 40 mph) winds. There is no way a TV mount will withstand that.
I am attaching the three positions mine are at. Mostly I set horizontal when I first arrive at a campsite, unless the trailer rear is facing south. And in very special circumstances, I will set to tilt forward but this is not common, typically horizontal is more than adequate.
@NotYourGuy
We have the factory flexible panels (193-watts) mounted to the roof, and for spring, summer and early fall, provides enough energy to keep,the battery charged whilst boondocking. We have a 200-amp AGM. For late fall and summer deep,shade camping we got two 100-watt portable panels to use when the roof is in deep shade (partial shade in summer still keeps battery charged) or for late fall camping where more is better.
Also, are you towing that with a 2007 Legacy?!?!?!?!?!
2006
Odessa, Fl.
