I know this has been done by a few to address the slow draining sink in the older 400 models...which I have. I was prompted to do this because I was never too crazy about the plastic, see little value with the folding sink, and hated waiting for it to drain. I'm just not keen on paying $500 for the upgraded design. An early freeze last year made me take the sink out and inspect everything so, as most projects get started, thought now's the time. After trying this out on a few trips I don't feel it gets in the way or makes the space cramped. Some of the negatives is that you're adding about #20 (those porcelain sinks aren't light) so I had to put extra thought in making sure it's well reinforced and supported for all the vibrations in travel. That's why you almost never see the RV manufacturers do that kind of thing but there's not too many options for sinks this small. The faucet is a bit overkill but it's so nice and was only $23. I usually go overboard on making everything serviceable so it took a while to think it through but in the end it prompted the oval pockets which add visual interest and extra storage. I'm still working out some details on how to close off the lower portion while making it easy to access. That should always be a priority for pluming so you can inspect the ticking time bombs. Also, need to add finishing trim to hide some of the interfaces.
Sink:
https://www.amazon.com/gp/product/B086VFQNDC/ref=ppx_yo_dt_b_asin_title_o05_s01?ie=UTF8&psc=1Faucet:
https://www.amazon.com/gp/product/B07QCRFG5J/ref=ppx_yo_dt_b_asin_image_o04_s00?ie=UTF8&psc=1Pluming: All found at typical hardware stores
2018 T@B 400 (white w/ red trim)
Here's the upgrade. By just opening up the hole it's quite easy to interface with standard pluming. P-trap and vent is already there so no need to add. I got lucky that all the pluming was simple and standard even the 45 bends to get to the sink offset. No crazy mish-mash of fittings. Drains like a champ.
Nice work, and the curves and angles even show an eye for the art of it! Impressed!
nüCamp: 2019 T@B 400 Boondock Lite
2013 Tundra TRD 5.7L
Massachusetts
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
@ADRawli It's not a perfect match but Baltic birch is quite common and I think that's what they use. I'll upload more pictures as this evolves.
The Baltic Birch I use is the multi-ply high quality stuff you wont find at most of the big box stores except maybe Menards. I get mine from Rockler when they run their sales.
Massachusetts
PNW
PNW
RV Exterior Spray Port Hook-Up Connector. https://www.recpro.com/rv-exterior-spray-port-hook-up-connector/
Massachusetts
Very nicely done mod!
Did you free hand those curved cuts or do you have something better?
They look absolutely perfect.
Again, nicely done!!
Nice...I thought that might be the case. Do you have your own, or are there services out there to do one-off projects?
I'm thinking about doing the closet mod on my 2021 T@B 400 that another forum member posted - adding storage pockets to the back wall of the wardrobe. A CNC would be an ideal way to make the cutouts look great like yours do.
Thanks for the info and kind offer. I'm going to work on the plans for what I want to cut and will let you know when I have something more concrete to discuss.
I'm also going to look at what CNC options are out there...I really didn't know that it was even an option for home use.
Southern California
Full-timer since 2019
Here is a pix of the factory no sink install on our 2018 TaB 400:
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab
