I brought my beautiful little 2014 T@B 320S home yesterday. The RV dealer showed me all the features, but getting them to work myself is another story!
I almost went camping straight away, but it's a good thing I decided to get to know the trailer first, while plugged into electrical and still in my driveway.
I searched this forum, but I didn't find anything for an older model T@B like mine. Here are my questions (so far):
1) How does the little table collapse down? It has 2 sets of hinges and a spring. It looks like a finger guillotine, so I'm being extra careful. but it seems to be part of the bed platform, so it's kind of essential to figure out (photos attached)
(Later models seem to have a simpler table design, less prone to finger pinching)
2) Can I run the Alde heating while plugged into electric if the water tank is drained (for dry winter camping)? Does it also heat a boiler and will I run anything dry?
What settings do I use to run electric vs. propane heating? (photo attached)
Other than that, my only other 'panic' is around learning to back up, but that will come with time and practice.
I do not have any experience with the table you have, so I will leave that for someone who does. I have the Alde 3020, so I will leave it to others to help you with the 3010 model. However, you can heat the trailer without having any water in the Alde boiler tank. It will run on electric, but again, I will leave it to others to discuss the specifics and settings for the Alde 3010 model.
If you did not receive a copy of the Alde 3010 manual, you should obtain one and review it carefully. There is probably a copy in the
"User Manuals/PDF Files/Videos & Resources" folder on the left side of the main Forum page. Lots of helpful stuff can be found in those folders. If not, you should be able to find it on the Alde web site, or just Google "Alde 3010 manual."
I should have mentioned: I have the Alde 3010 manual but I did not understand what setting (B, C, or D) to use for currently being plugged in and was worried about a boiler. Sounds like I should try 'B' and see if I get any heat after a few minutes.
P.S. I agree with setting it at the "B" setting as described in the User Manual since you are plugging in at home, presumably with a 15 or 20 amp electrical outlet and may be using other electrical items as well. When you are hooked up to a 30 amp outlet (e.g., at an RV park) you can bump it up.
"To run the Alde on shore power only, move the left lever to B, C, or D. The difference between B and C is how much current is used by the Alde.
If running from a normal residential power source, use ONLY “B” otherwise the power cord will heat up. There are some reports that US power systems cannot fully use the “D” setting because our power voltage is 110, not 220"
I'll try it out tomorrow during "driveway camping - day 2"!
Still hunting through manuals for info on that pesky table...
Many thanks! So relieved that I'm not the only one stumped by the *$(@% table!
Can't wait to try it out during tomorrow's driveway camping
Do you like the table? Would you prefer a simpler one? or is it nice to have it out of the way while sleeping?
Many people don't like the table because it's unwieldy. We still use it because it's so sturdy, and works well at the campsite as an outdoor table. Sometimes we'll leave it home and simply use planks for that part of the bed.
In the US and Canada, positions B and C are effectively the same, and either can be used with a 15 amp circuit. Position D will overload a 15 amp circuit but can be used with a 20 amp circuit.
These things are dictated by the capacity of your house circuits. So long as you are using a standard 30 amp RV cable, the power cord has nothing to do with it.
If you want to learn more about the differences between NA and European Aldes, see my comments in this discussion.
SLIDER 1: If shore power is available, use this to turn on the electric heating elements. US and Canadian Aldes have two identical elements; you can turn on one (I), the other (II), or both (III). Turning on both heats things faster, but it will work no matter what you do. Relax, don't worry, have a homebrew!
SLIDER 3: Once you have selected your power source, use this to turn on the room heat and hot water, or just the hot water alone. Relax, don't worry about why there is not a "room heat only" setting, have a homebrew!
Here is the thread: https://tab-rv.vanillacommunity.com/discussion/3347/alde-panel/p1
If you find the Adle User manual a bit confusing . . .
I found a Brief Overview for Regular Folks on an older rental unit web-site.
It is a picture file, have attached the file as it is larger than Forum Posting size guidelines.
Adventures: 58 Nights: 405 Towing Miles 50,180
As for that rental unit literature, it--just like the 2014 T@B Maxx manual @Mellow_Yellow originally quoted--is also wrong. North American Aldes have lower wattage heaters than their European counterparts. This allows them to be operated at 120 volts (even both of them at the same time) without exceeding 20 amps of current. Contrary to those sources, you absolutely can use the three lighting bolt setting so long as you have at least 20 amp service.
This has been insightful, however. With at least two published sources (including one from LG/PV/nuCamp) providing false information, it's no wonder the analog controls have been such a bugaboo for so long.
I think it is a clever dual-duty design, despite being a bit bulky. That said, I promptly moved mine to the garage and replaced it with a homemade slat system. We rarely take up the bed anyway, and the slats open up a lot of premium storage space under the bed that would otherwise be filled by the table legs.
As an added bonus, on the rare occasions when we do set the benches up, a few slats make for a very functional coffee table. :-)
We got a light weight adjustable folding plastic table from Aldi in the spring. I don't think they carry them year round.
It's easy to set up, light weight, and rain proof so you can take it outside.
It's similar to this one except it was black, more rectangular and less expensive
https://www.amazon.com/dp/B0074HYWFG/ref=twister_B07TF9T4R4?_encoding=UTF8&th=1
Amazon has a huge amount of tables that are a lot easier to move, use than that monstrosity that came with the T@B
Tampa FL
2021 Toyota Highlander
