We have a 2021 Tab 320, Boonbock version camper. We've taken it out a few times now but still are having some issues getting consistent warm/hot water, so I'm starting to question our hookups. We do not fill our tank, we have connected to the campsite water supply, so we set up on the city water valve setting, we do not run the water pump. I've learned that we should have the water on the hot setting, so are we doing something wrong, or am I just too impatient?
0 ·
Sold 2023 Tab 400
Sold 2018 T@B 320S
Alde has ~2 gallons capacity of Hot Water.
And at start of needing hot water one has to flush all the cold water from the feed lines,
then you get 2-gallons of hot followed by colder as Alde tries to heat up more water.
Sea Showers work best; short periods of hot water running, no water on soaping, then rinse.
The trick (and I'm still not a master) is to time how long the Alde needs to heat more water vs. how fast the feed lines become cold water to avoid a blast of colder water.
Remember you are camping not at home.
If you need 'at home' hot water a different style trailer would be needed.
All of the info and advice above is good, but whether or not it applies to your situation depends upon the specific nature of your problem.
With the Alde Flow aux tank, on the newer TaB400 (the OP’s 320 does not have the Flo), longer showers are possible, as water,get,pre heated I’m the Flo aux tank, and heated to final temp in the main Alde heater unit.
Any way, I always set the the Alde control panel to,Max hot water/shower mode when washing up or showering. This gives more hot water, and quicker heating recovery times.
The same method of filling the Alde tank applies when using the TaB fresh water tank, except you turn on the pump then open the hot faucets. BTW - if you plan to camp using your TaB fresh water tank, a way to save water, time and aggravation is hook up to city water before you leave home and fill the Alde tank. That way, when you arrive to camp, you don’t need to waste any water filling the Alde tank.
