I have been contemplating adding a small light near the glycol tank that would allow me to easily see the glycol level as needed. I took the time over the weekend to install a small license plate LED light near the bottom of the tank. I also installed a switch flush to the plywood cover above the tank. This was relatively easy and although the closet area is small in our 400 it was worth the effort. I installed the switch on the cover above the glycol tank and ran the wiring down into the converter area where I picked up a 12V hot wire. This is a worthwhile mod and there will be no more guessing or looking for a flashlight.
3 ·
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
2013 Tundra TRD 5.7L
Massachusetts
Thanks, this one is going on my to-do list.
In the 320 model, I believe there is a 12v line available in the compartment above, as I recall.
2019 T@B 400 Boondock
https://www.amazon.com/Single-Switch-12-Volt-Trailer-Camper/dp/B078MKLQKZ/ref=asc_df_B078MKLQKZ/?tag=hyprod-20&linkCode=df0&hvadid=312089957955&hvpos=&hvnetw=g&hvrand=13445283433473836881&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9017578&hvtargid=pla-570924461998&psc=1
