I saw other threads about extending stabilizer reach, but not specifically on the SnapPads. My BAL feet are 5.5 inch square, so I got the "MINI Square 5" model. They were VERY easy for me to put on by myself. Lots of dishwashing soap, and I just used my hand crank to push the feet into the pads. I cleaned them thoroughly first. They have a substantial weight and feel.
We shall see how they stay on. If anyone can bash these things off, it'll be me! I hopelessly mangled my step over the Summer on a rocky forest road. I cranked them up and there's no conflict. The lip is about 1.5" thick sticking down, but there are other things that stick down farther (tank valves and such).
"Before" photo:
"After"
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab
https://tab-rv.vanillacommunity.com/discussion/6900/leveling-an-outback-boondock-t-b
https://rvsnappad.com/products/mini-6-4-pack
Trips - 48 Mileage - 63,452
I chatted with SnapPad. The pads only add 1" in height. The "minis" (6") weigh 2.4 pounds each (9.6 pounds for the set). They expect to have them back in stock in a couple of weeks, for those who are looking for them.
St Catharines, ON
It is unlikely that a direct lightning strike is going to be dissuaded by a half inch of rubber after traveling thousands of feet through the air. while a charge may develop from the EMP of a nearby strike, unless you have one foot in the camper and another outside on the ground, you are in no danger. The electronics are safer, too, with no path to ground.
2012 Toyota Sequoia Platinum
Nashville, Tennessee
2022 NuCamp T@B 320S Boondock
2023 Volkswagen ID.4 Pro S Plus AWD
