Hey y’all, we love our 320 but just got a second pup and almost certainly will need to up size to the 400 for next season.
I did an Li battery upgrade on our 320 and will definitely only be Li from here on out. This time though I’d like to get to 300-400ah as we pretty much only Boondock.
Tried searching without much luck, can anyone point me to some info / threads on the battery compartment in the 2021 400 so I can see what’s possible?
To clarify further, it seems like I could def drop in two of the BB 100ah models that are shaped like the 6v AGM but curious if I can do more. Thanks!
You could add extra Lithium batteries in the front of this area, as long as the weight does not exceed the floor loading limits.
Sold 2023 Tab 400
Sold 2018 T@B 320S
@dsfdogs here’s a picture of the little monster caught in a brief member of zen between attacking my hands
Sold 2023 Tab 400
Sold 2018 T@B 320S
Adding the Lithium batteries in front of the existing AGM batteries in the storage area depends on the mass of the battery (weight per square inch of the surface area of the battery) not its total weight.
"The available battery area in the battery compartment is about 20"L x 7.5"W x 11"D.
The battery compartment itself is 25"L x 7.5"W x 11"D total but some of the area is taken up by the vent hose. Some of that space could probably be reclaimed by removing the vent hose"
Portland, OR
Portland, OR
if so what are the batteries it comes with?
@kbdigitiqe the 400's(2021 Boondock) come with 2 AGM 6v 224ah batteries.
Portland, OR
I’m trying to understand how I’ll use my outboard Li charger to top up before each trip and hoping it doesn’t involve having to access the entire battery compartment??
