Storage space is everything, so does anyone have any recommendations for a lightweight and compact water hose? There are several out there but it is hard to tell what's good with reviews all over the place.
0 ·
https://smile.amazon.com/gp/product/B01N1FB8WV/
Regardless of what you choose, make sure it’s drinking water safe.
San Diego, CA
www.airbossone.com
Think I bought it at Northern Tool where they had both the regular kind and the drinking water kind.
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
Did manufacturer recommend against constant pressurization?
Don't put a ton of faith in Amazon reviews. Rely more on SME'S...you know...folks on here! ;-)
San Diego, CA
www.airbossone.com
1/4-in Kink Free 25-ft Polyurethane Air Hose https://www.lowes.com/pd/Kobalt-1-4-in-Kink-Free-25-ft-Polyurethane-Air-Hose/3303484
Ontario, Canada
Sold 2023 Tab 400
Sold 2018 T@B 320S
50' Zero-G: $64
50' Camco hose: $18
Here are the reviews of those small percentage who this hose didn't work well for. The 1-star reviews can be quite insightful
https://www.amazon.com/product-reviews/B014M9PEXC/ref=acr_dp_hist_1?ie=UTF8&filterByStar=one_star&reviewerType=all_reviews#reviews-filter-bar
I heated it, froze it, and generally beat the heck out of it for over 200 nights this year without any problems.
Jeff & Amy
The 25 foot zero must be out of stock most places and it's listed as $62.
Most of those bad reviews are from a few years ago. Maybe they have made them sturdier?
Tampa FL
Some of the problems with the ZeroG is likely the 50' length, both the others are 25'.
For ZeroG:
- The unrolled length often kinks when in use restricting flow until I work them out.
- It is heavier to start and more so when is water trapped in it as it is difficult to impossible to get all the water out of it without fully unrolling it.
- As an engineer I'm leery of the aluminum fittings seizing on brass valves etc.
- I'm also not fond of the large size of these fittings. I can no longer close and lock the T@B city water connection with the hose installed.
- The woven cover picks up dirt much more readily and is harder to wipe off than the other hoses.
That being said I had originally purchased the West Marine hose to extend the Camco one that came with the T@B. It quickly took the place of the Camco. The West Marine hose is not as stiff, particularly when cold. It kinks less frequently than the Zero G, easier to drain, and has just the right stiffness to make coiling easy.I'm thinking about returning to the Marine hose, never again on the Camco.
Your mileage may differ.
As with everything else, choices are good, because people have different preferences. Personally, I’ll never go back to dealing with regular hoses, the traditional style one I use at dump sites for flushing is only 10 feet and is still way more annoying and bulky to store than the ZeroG type.
