I think this has been discussed but I can’t find the thread.
On all new 2021s the space between the stove and sink has pretty much been halved by the mew placement of the stove. On older models that space was huge because the stove was more to the right. Why did they move the stove over?
I see the argument of now having equal room on both sides of the stove but, for me at least, I’d think most people would rather have one large space versus halving that space...right?
If this was just an arbitrary decision I’ll just stick it in my bin of questions along with “why is the exterior storage door so small and unlockable now?”
Is there a functional reason for the change?
As far as the door goes I do wish it was slightly larger. I do like how tight it seals and the magnetic catch on it though. But I guess they just went with an off the shelf door that came in that size. And it should come with a lock. I saw a photo of that same door with a lock in it months ago but for the life of me can't find it again. So I believe it exists. If anyone finds it let me know!
2020 Tacoma TRD Off-Road
I agree with both your comments. The counter layout works great...it is actually nice to have some counter to the right of the stove.
And the outside storage door could certainly use a 'super-sizing'...but is usable - particularly given the relatively small space that is available behind it. But even so, a longer door would make the small space a bit easier to use. I use tool bags from Harbor Freight to store a lot of stuff under there...the bags just fit through the door, but allow me to get 4 of them in there and keeps things pretty organized.
Thoughts from 2021 owners?
San Diego, CA
www.airbossone.com
I like the larger space between the sink/stove but no doubt I could get used to the 2021 version.
Another curiousity in the 2021...the cubby under the 3-way fridge. How deep is that? Seem to recall there is a fair amount of wiring, plumbing, etc. under there.
San Diego, CA
www.airbossone.com
I don't have the measures but that cubby is pretty deep. Our 10lbs chihuahua sleeps in there. If he's not with us we put our shoes in it.
Plus as @bergger noted, it would actually act as a splash guard for the bed if turned sideways with the current glass top.
@bergger
Thanks for the info on the cubby. I may look into opening that up to see if there's an opportunity to add a few cubic feet of storage. Every little bit helps.
San Diego, CA
www.airbossone.com
Found I missed the extra counterspace with the lid closed and just from an aesthetics standpoint, liked having the glass top covering the stove. Certainly an option, tho.
Do appreciate the fact that nuCamp doesn't seem to be afraid of reconfiguring it's rigs and I'd suspect some of those reconfigurations are a direct or indirect result of customer feedback. Another thing I like about the support from Sugarcreek.
San Diego, CA
www.airbossone.com
I had the same problem with one of the screws falling out - on two different trips! I got it good and tight now...
It's literally the only thing that has come apart in 8K miles of travel - and required almost no effort to repair!
My last adventure for 8500 miles/7+weeks I had 2 minor issues. The screws on the lid (took 2 minutes and a nut driver) and I had to reset the Alde once. And thanks to whomever posted on here about how to do that...much appreciated. Took longer to get through all the bedding and mattresses and lift the access panel on the bed than it did to reset the thing.
Very impressed with this rig to date. One always hears horror stories about buying a new RV and what they have to deal with time and again under warranty.
Knock on wood...
San Diego, CA
www.airbossone.com
Yep...here's what it looked like prior to the installation of the Air 8 Plus back in July. They've rerouted the A/C ducts a bit to straighten and shorten the runs. Can't do much with plumbing without serious effort. Doubt I'll have much room but I'll give it a look.
San Diego, CA
www.airbossone.com
