a shoe holder
sbhtennis
sbhtennis Posts: 69
edited January 2021 in Modifications & Upgrades
 I am not sure if someone already posted this idea  but if not  .....
 I had purchased this tension rod and actually forgot where i  was going to put it when the idea to set it up down under the side sitting cushions and by the carbon monoxide detector  came as a  possible solution to--- where to keep our shoes without tripping over them every time. So the tension rod just goes under the  seat and then the shoes slip in. I am not sure if they will hold my partner's bigger and clunkier shoes but at least maybe our clogs which we wear in the Tab. I have a 2016  400 Max S model.
@sbhtennis - photos too large and deleted.  https://tab-rv.vanillacommunity.com/discussion/47/what-size-should-my-posted-forum-photos-be#latest
    Sharon_is_SAM Posts: 10,035
    @sbhtennis - nice idea.  We did the same thing in the wetbath on the driver side wall over the little ledge made by the shower pan.
    BTW- unless you have recently upgraded, I believe you have a 320 S Max.
  • rfuss928
    rfuss928 Posts: 1,192
    edited January 2021
    Sorry - couldn't resist.
  • I hope these photos are now in the correct size.
    Thanks @sbhtennis!  Perfect.
  • Watch the crocs over the convertor vents.  I stood a mattress in front of it and the mattress got pretty hot.  I’m sure the shoes don’t block them as much but.....
    Tampa FL
  • Thank you Tampakayaker. I did not think of that area as one of of much heat.
