a shoe holder
sbhtennis
Member Posts: 69
I am not sure if someone already posted this idea but if not .....
I had purchased this tension rod and actually forgot where i was going to put it when the idea to set it up down under the side sitting cushions and by the carbon monoxide detector came as a possible solution to--- where to keep our shoes without tripping over them every time. So the tension rod just goes under the seat and then the shoes slip in. I am not sure if they will hold my partner's bigger and clunkier shoes but at least maybe our clogs which we wear in the Tab. I have a 2016 400 Max S model.
@sbhtennis - photos too large and deleted. https://tab-rv.vanillacommunity.com/discussion/47/what-size-should-my-posted-forum-photos-be#latest
2
@sbhtennis - nice idea. We did the same thing in the wetbath on the driver side wall over the little ledge made by the shower pan.BTW- unless you have recently upgraded, I believe you have a 320 S Max.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Sorry - couldn't resist.
I hope these photos are now in the correct size.
Watch the crocs over the convertor vents. I stood a mattress in front of it and the mattress got pretty hot. I’m sure the shoes don’t block them as much but.....2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL0 -
Thank you Tampakayaker. I did not think of that area as one of of much heat.0
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
