Bought new 320 boondock, I have big 2500HD pickup now but it's so over kill
Looking at Grand Cherokee, but slightly more capacity & $$ than I like
Also like the Subaru,
Anyone tell us what you tried and didn't work out?
Do you love what you're using now?
Planing going into Canada Banff etc with real steep hills and onward in Alaska this summer
Bob
Just a heads up because not everyone is aware: Neither Subaru is compatible with physical anti sway bars due to their unibody construction. For some folks, that’s a deal breaker.
The Grand Cherokee is a very popular tow vehicle around here. The Toyota Highlander is another possibility you might want to look into.
We tow our RV's with a 3/4 ton Suburban with a 8.1 496ci , and towing our 320S Boondock with it, is the true definition of "dont even know its back there", lol . MPG is the same if we are empty, or towing the 320 . Maybe there might be a 1 mpg difference.
Now we did have a Dodge Caravan with the 3.6 3600lb tow rating and while it was a doable combo with the 320 , MPG really suffered when towing . Empty was close to 30 on the highway, when towing the T@B we dropped in to the 12's to 14's, and it was working really (too) hard. Had to keep it in 5th (out of 6) gear most of the time , unless it was a really flat long stretch .
The Suburban doesn't even break a sweat , and we are still pulling at about 12-14 MPG towing . It a WAY less stressful towing experience ! I can literally forget its back there !
We also have a Keystone Ouback 6500lb 30' Travel Trailer, and the Sub handles that well also. Just a way easier towing experience when we are towing the T@B (and way better MPG's ! , lol) vs. the big Outback.
Keep what you got and get a nice cap for it !
2024 NuCamp T@B 400 BD, Charcoal / White
reading older threads most folks don't use anti sway?
9 mpg is a little hurtful , maybe it needs a good tuneup ?
I am in the boat business , and the 8.1 496 is a common marine engine used in cabin cruisers and performance boats . They just run ......... period . They barely even need maintenance. Why GM phased out this engine is a mystery . Too much competition for the Duramax , prob.
We have service trucks with 5.3's, 6.0's and 8.1's . The 8.1's NEVER need anything . Just have to watch a few of the common 8.1 problem areas (same for 5.3, 6.0) . Exhaust mainfold gaskets , damper pulleys , and the common 8.1 "using" some oil . Some worse than others. Our Suburban is not bad , about 1 quart per 1k miles.
If you are determined to switch up tow vehicles , you cant go wrong with a Grand Cherokee . If it were me, I would get the 5.7 ........so there goes the MPG again . Great towing platform though , with the V8. The 3.6 should also be ok , as they are pairing that with an 8 speed transmission now. Just dont care for the shorter wheelbase of the GC for towing.
If we ONLY towed our T@B , I would prob jump into a new body style Suburban with the 5.3 (our 30' outback would be too much for the 5.3) . I dont know how anyone can camp with a 320 , and not have the room in the tow vehicle for all the "stuff" that wont fit in the T@B ! A Jeep Grand Cherokee just wouldn't do it for us .
In your shoes I would throw some plugs in the 2500, change the oil in the motor, tranny, transfer cases, make sure tranny mounts and motor mounts and brakes are happy, replace all of the filters and run it another 75,000 miles.
But it is big for my with drive she want new and smaller.
I just found as a tow vehicle the Gran Cherokee "Trail Hawk" had so may tow related features it was a no brainier at least for our needs, it has air suspension, instrument that shows the angle left right and front back. just push a button to level up.
And we can really go off the woods or desert with or without the TAB,
also the 320 were getting is the Boon docking option so it all makes sense.
If anyone is considering a new TV take to time to read thru the literature from Jeep.
With the right deal and incentive's they are in low $40's
Your 2500 is a very capable and reasonably comfortable TV.
If you're determined to get a more efficient yet very capable TV, I would recommend something with a diesel powertrain. I have 10+ years and 80k miles traveled towing with a Touareg TDI. We're always very comfortable and never concerned with capability. 16-18mpg towing, 28-31mpg otherwise.
Took my time and found a one-owner, well cared for Tahoe Z71 with all the bells and whistles. I did set aside funds to go thru the running gear, tune up, and change all fluids, belts, hoses, etc. Ended up putting in new H20 pump and radiator and transfer case. All told, that still only came to about 6 months of an average new car payment. Just completed 8500mi cross country adventure with the T@B. Not a hiccup.
In fact I'm pleased enough with it that I turned in my leased 2019 Volvo XC-60 early. Doubt I could find a new TV that has the Tahoe features and increased MPG sufficient to offset the monthly payments and increased insurance costs.
But that's just me...
San Diego, CA
www.airbossone.com
i like the 4dr truck, room for my Catahoula dog or guests and a truck bed for stinky camp stuff.
Odessa, Fl.
It can be yours for a low low price starting @ $43,000.
Of course the extra MPG savings will be eaten away by the higher cost of diesel fuel.
Tampa FL
Tampa FL
Towing the T@B 320 i got between 15.5 and 18.3.
Tampa FL
