Buying tow vehicle, suggestions
NovaTabNovaTab Member Posts: 91
edited January 2021 in Trailer & Towing
Bought new 320 boondock, I have big 2500HD pickup now but it's so over kill
Looking at Grand Cherokee, but slightly more capacity & $$ than I like
Also like the Subaru,
Anyone tell us what you tried and didn't work out?
Do you love what you're using now?
Planing going into Canada Banff etc with real steep hills and onward in Alaska this summer
Bob
2021 TaB 320 Boondock, Gran Cherokee TrailHawk
    edited January 2021
    Whether or not a Subaru is a good tow vehicle depends entirely on the model and your camping style.
    The Ascent is a decent workhorse for towing a 320; every trim level except the base model has a 5000 lb overall towing capacity and 500 lb tongue weight limit, so you can carry pretty much anything you want. The towing package includes a 7 pin connector, and it has anti sway built in.
    The Outback is more of a minimally acceptable tow vehicle, and ONLY the 2020 or 2021 XT models should be used, as they have a 3500 lb towing limit. They will work, but between the lower limits and mere 900 lb payload (which includes driver, passengers, cargo, pets, and your trailer tongue weight), they’re not the best choice if you’re the type who wants to carry a bunch of additional stuff like bikes, kayaks, heavy coolers, etc.
    Just a heads up because not everyone is aware: Neither Subaru is compatible with physical anti sway bars due to their unibody construction. For some folks, that’s a deal breaker.
    The Grand Cherokee is a very popular tow vehicle around here. The Toyota Highlander is another possibility you might want to look into.
  • B0atguyB0atguy Member Posts: 224
    edited January 2021
    Keep the 3/4 ton 2500HD . It is not overkill , you will appreciate when you need to climb some steep grades and when you find yourself in Alaska . With the 2500HD (not sure of your engine ? 6.0 ?) , you will barely notice a MPG difference towing the T@B , and it will barely be breaking a sweat so it will be easy on the drivetrain and engine to keep it nice and reliable.
    We tow our RV's with a 3/4 ton Suburban with a 8.1 496ci , and towing our 320S Boondock with it,  is the true definition of "dont even know its back there", lol . MPG is the same if we are empty, or towing the 320 . Maybe there might be a 1 mpg difference.
    Now we did have a Dodge Caravan with the 3.6 3600lb tow rating and while it was a doable combo with the 320 , MPG really suffered when towing . Empty was close to 30 on the highway, when towing the T@B we dropped in to the 12's to 14's, and it was working really (too) hard. Had to keep it in 5th (out of 6) gear most of the time , unless it was a really flat long stretch .
    The Suburban doesn't even break a sweat , and we are still pulling at about 12-14 MPG towing . It a WAY less stressful towing experience ! I can literally forget its back there  !
    We also have a Keystone Ouback 6500lb 30' Travel Trailer, and the Sub handles that well also. Just a way easier towing experience when we are towing the T@B (and way better MPG's ! , lol) vs. the big Outback.
    Keep what you got and get a nice cap for it !
    2024 NuCamp T@B 400 BD,  Grey / White
  • rh5555rh5555 Member Posts: 520
    Now that Jeep have announced their next generation Grand Cherokee, you may be able to get a deal on the current model.  I don't remember seeing a singe negative comment about the Grand Cherokee as a TV on this forum.
  • NovaTabNovaTab Member Posts: 91
    the 250HD has the 8.1 gets about 9mpg, with 170 miles on it a bit too old for a big trip.
    reading older threads most folks don't use anti sway?
    Agree with @B0atguy, I would use what you have, mileage will be no less towing and maybe better than some over taxed minimal tow vehicle.
    edited January 2021
    If you load the trailer correctly, many people find anti sway bars unnecessary with a 320. But plenty do use it.
    edited January 2021
    Out of all the vehicles we own, I trust my old 8.1 the most , lol . They are just about as bulletproof as you can get for a towing vehicle. 170k is barely broken in for a 8.1 . They just run forever . The rest of the truck ........well that seems to vary depending on region and the amount of body rust/rot . But the drivetrain will outlast the body . Our 2500 Suburban was a California truck, so luckily, no rust anywhere .
    9 mpg is a little hurtful , maybe it needs a good tuneup  ?
    I am in the boat business , and the 8.1 496 is a common marine engine used in cabin cruisers and performance boats . They just run ......... period . They barely even need maintenance. Why GM phased out this engine is a mystery . Too much competition for the Duramax , prob.
    We have service trucks with 5.3's, 6.0's and 8.1's . The 8.1's NEVER need anything . Just have to watch a few of the common 8.1 problem areas (same for 5.3, 6.0) . Exhaust mainfold gaskets , damper pulleys , and the common 8.1 "using" some oil . Some worse than others. Our Suburban is not bad , about 1 quart per 1k miles.
    If you are determined to switch up tow vehicles , you cant go wrong with a Grand Cherokee . If it were me, I would get the 5.7 ........so there goes the MPG again . Great towing platform though , with the V8. The 3.6 should also be ok , as they are pairing that with an 8 speed transmission now. Just dont care for the shorter wheelbase of the GC for towing.
    If we ONLY towed our T@B , I would prob jump into a new body style Suburban with the 5.3 (our 30' outback would be too much for the 5.3) . I dont know how anyone can camp with a 320 , and not have the room in the tow vehicle for all the "stuff" that wont fit in the T@B !  A Jeep Grand Cherokee just wouldn't do it for us .
    I’m I’m kinda partial to my Colorado diesel.
    With the 2500 you already own a perfect TV. Rear wheel drive with selective 4 wheel for when you need it, lot's of HP  and torque, a bullet proof motor and a truck chassis. You can't do much better without buying into a modern equivalent. After a 2500 any Subaru will leave you feeling drained and stressed every time to finish a day on the road. Going from capable to marginal is a step backwards. Jeep is a Jeep is a Jeep. If you try to make a move from a Chevy to a Jeep it will make you crazy. There is a Jeep way that things are done that only someone who has always liked Jeeps can appreciate...a Jeepy kind of funk and now with a bit of an Italian flare.
    In your shoes I would throw some plugs in the 2500, change the oil in the motor, tranny, transfer cases, make sure tranny mounts and motor mounts and brakes are happy, replace all of the filters and run it another 75,000 miles.
    You can buy a lot of fuel for the difference in price between a paid for older vehicle and a new one that likely will not get a huge increase in MPG towing. Unless towing a ton, almost never worth it. I am towing a Tab 400 with a 20 year old Ram 2500, solid long ago paid for truck, 315k and counting.
    Well we rehearsed this till the cows came home,
    We love the 2500 but it's 13 years old and we towed a 31' Airstream for several years weighing about 7K, never felt it strain up mountains and would do 75mph on the right roads like nothing even with semi's passing on both sides.
    But it is big for my with drive she want new and smaller.
    I just found as a tow vehicle the Gran Cherokee "Trail Hawk" had so may tow related features it was a no brainier at least for our needs, it has air suspension, instrument that shows the angle left right and front back. just push a button to level up.
    And we can really go off the woods or desert with or without the TAB,
    also the 320 were getting is the Boon docking option so it all makes sense.
    If anyone is considering a new TV take to time to read thru the literature from Jeep.
    With the right deal and incentive's they are in low $40's
    The Jeep GC or Wagoner is a good choice for towing RVs.  You get all the bells and whistles, great backup cameras, and rear axle drive that is more stable when towing larger loads.  The TaB 320 is small enough for mid size SUVs, but going with a larger TV allows upgrade to the 400 or larger RV...
    Prior to my Colorado, I had a ‘14 Grand Cherokee with the eco diesel. It was great, comfy, and tons of torque, as you would expect with a diesel.
  • rfuss928rfuss928 Member Posts: 1,095
    NovaTab
    Your 2500 is a very capable and reasonably comfortable TV.
    If you're determined to get a more efficient yet very capable TV, I would recommend something with a diesel powertrain.  I have 10+ years and 80k miles traveled towing with a Touareg TDI. We're always very comfortable and never concerned with capability.  16-18mpg towing, 28-31mpg otherwise.
  • MarcoMarco Member Posts: 18
    My 2017  Toyota Tundra 4.6 gets about 15-16mpg pulling my 2017 320S. Its a little overkill but a lot better than towing with a 2019 Toyota hybrid AWD.
    I tend to agree @N7SHG_Ham.
    Took my time and found a one-owner, well cared for Tahoe Z71 with all the bells and whistles. I did set aside funds to go thru the running gear, tune up, and change all fluids, belts, hoses, etc. Ended up putting in new H20 pump and radiator and transfer case. All told, that still only came to about 6 months of an average new car payment. Just completed 8500mi cross country adventure with the T@B. Not a hiccup.
    In fact I'm pleased enough with it that I turned in my leased 2019 Volvo XC-60 early. Doubt I could find a new TV that has the Tahoe features and increased MPG sufficient to offset the monthly payments and increased insurance costs.
    But that's just me...
    San Diego, CA
    www.airbossone.com
    edited February 2021
    Toyota Tacoma.   I had a 2004(first generation).  It towed great.  But being 2wd and planning a cross continent to Ak trip I talked myself into a new 2019 4wd.  Both took a mpg hit when towing.  From about 22mpg empty to about 15 mpg loaded with trailer and gear.
    i like the 4dr truck, room for my Catahoula dog or guests and a truck bed for stinky camp stuff.
    Odessa, Fl.
    Dodge has a 6 cylinder Ram 1500 ecodiesel that will get 33 MPG and tow 12,560 pounds.  It has special low rolling resistance tires to help with the mpg.
    It can be yours for a low low price starting @ $43,000.
    Of course the extra MPG savings will be eaten away by the higher cost of diesel fuel.
    Tampa FL
    I am in the DC area, and Diesel is less expensive the High Test, and about the same price as Mid Grade...I believe savings can be realized!
    In FL it's quite a bit higher than regular or premium gas.  The station I go to the diesel is 30 cents more than regular.
    Tampa FL
    A 10% increase in fuel cost is easily justified by the 50% increase in fuel economy with diesel powertrains.
    I can get 20 to 24 MPG highway with my RAM 8 cylinder if I stay between 55 and 60.
    Towing the T@B 320 i got between 15.5 and 18.3.
    Tampa FL
  • ArwenArwen Member Posts: 68
    I tow my T@B 320S Boondock with a Jeep Cherokee Trailhawk and it has more than enough power.  I get between 16 and 19 MPG towing. I don't have sway bars, but am careful at how I load my T@B (heavy items like the tent addition just in front of axle).
    Arwen: Northern NH; 2018 T@B 320S Boondock, silver/blue; TV: blue 2018 Jeep Cherokee Trailhawk
