I've been using propane a lot for my Alde heat, every night in southern California where
I am staying this winter. While washing my 2019 T@B400 yesterday I notice the outside Alde burner vent is scorched. I imagine the propane burner air being exhausted is very hot but I would expect Alde accounted for that when choosing the vent material. Either they didn't or I have another problem. Anybody else notice this on their Alde vent?
I am using propane now because I am camped at my daughter's house with a 15amp extension cord for power so I can't turn the Alde up past 1000 watts, which isn't enough for me to maintain 70 degrees in the cabin with nighttime lows of 35 degrees. I don't boondock and when at a FHU sites I have 30 amps so electric power is plentiful for heat, no propane necessary. Did I mention I live in my T@B?
I'm going to buy an infra red thermometer to check the temperature at the vent. The thermometer also will be handy checking my brakes temp when I am towing. More later.
Southern California
Full-timer since 2019
Looks like scorch to me. As someone noted earlier there is similar but less discoloration at the side of the vent
Southern California
The Adle for example was not intended to run (burner on) every night, all night, 365 days a year. System components are being over stressed with resulting degrading of overall system.
Adle Support claims unit is up to task of full-timing, see Jan-18 post below by jimcenname
Things to do / consider to improve full-time-living in a trailer not intended for such usage:
1] Get the extra blankets (if weight is a real issue, then remove something not needed for winter)
or shift to a quality sleeping bag for winter months.
2] Shift your daily morning shower to a mid-day or early evening shower. T@B cabin will already
be warm. Might also shift to fewer showers per week.
3] Remember you must adjust to limits of trailer when using it beyond it's intended design goals.
Good luck
Adventures: 58 Nights: 405 Towing Miles 50,180
Southern California
Pictures look more like material discoloration and soot.
Should be able to clean away soot but not discoloration.
Southern California
Alde customer service responded to my inquiry, I asked if the 3020 HE in my 400 is hearty enough for full-time use. Response is that Alde is and with no extra maintenance required. See email attached.
Southern California
Southern California
