I just got my new 320S home and took it out to the local storage place, which is outdoor although on concrete. Is there an issue with storing my trailer with the tongue jack caster in place (and rear wheels chocked) --as opposed to removing the caster and installing a tongue jack foot?
0 ·
https://www.amazon.com/dp/B002R0J3MC
...(even though I'd prefer a heavier rubber version) instead of the flat tongue jack stand, since the wheel extends down further, so there's less rotating of the jack required. I only use the flat jack if I have to be level on an uphill and the wheel is too long.
If you're a real belt-and-suspenders type you could even drop the stabilizers when parked. Many of us do that as an added anti-theft measure but it also keeps the unit firmly planted (particularly if you plan to go in and out of it while in storage).
My impression is that the oft-expressed concern about "flat spots" is highly over-rated for modern radial tires that get seasonal use. YMMV.
My passenger side tire went flat and those two stabilizers got pretty tight. When I initially parked, they were just lightly touching the concrete.
Any damage in particular I should look for?
Tampa FL
For servicing purposes, I still use the no-longer-recommended method of raising the wheel using only the rear stabilizers and tongue jack. Others have gone so far as to replace their stabilizers with actual jacks and use them to level the camper. (I still think that is pushing your luck but thus far I'm unaware of any damage cause by doing this, so to each their own.)
In short, I don't think you have anything to worry about from your brief episode of tight stabilizer syndrome! :-)
I should note I'm talking about 320s here. 400s are considerably heavier and may be more susceptible to damage from improper loading of the stabilizers.
Stabilizers look OK. I was more concerned about warping the T@B frame.
Currently I have that side jacked up and resting on wood blocks (under that tiny jacking point L angle bar) until I can remove the tire and take it to a shop Friday after my DR appointment. I didn't see anything stuck in the tire and couldn't hear any escaping air after I re-inflated it. At first I thought the valve was leaking but I sprayed it with soapy water and didn't see any bubbles.
Tampa FL
