2021 Tongue Box Dimensions (320)
ScottGScottG Administrator Posts: 5,629
edited January 2021 in Trailer & Towing
Can anyone provide basic dimensions for the new 2021 320 tongue box? I seem to recall them posted here at one point, but can't locate them in a search.
Am I correct that the new box should be able to easily accommodate a 20lb propane tank and two batteries?
Anyone know if the rear profile of the new box is the the same as the old? Specifically, will it match the lines of an older 320?
Is the new 320 box different from the new 400 box?
I'm considering various options for upgrading my front storage--mostly for the purpose of accommodating two batteries. The new tub is pretty but also pretty pricy so I don't know if I'll go that route but would at least like to consider options in addition to a standard square aftermarket box.
So many questions... Thanks for any info you can provide!
  • cyoungcyoung Member Posts: 54
    35 1/4" long x 18 1/2" tall x 17" wide, overall outside dimensions. Yes a 20lb gas bottle and 2 6volt batteries do fit.
    2021 320 BOONDOCK, 2017 F150 2.7 ECOBOOST
    I would imagine easily; my old style boondock/outback tub fits the same, and the new one is measurably larger.
    Thanks much, @cyoung and @4ncar. Sounds like this would work, at least in terms of having enough floor space for all the goods.
    I have another specific dimension question. How wide (front to back) is the little trough designed to hold a sewer hose? Whatever I end up doing I would want to retain my closed sewer hose tube holder in its existing position mounted behind the tub but along the front of the trailer.
    I'm wondering if the trough is wide enough that I could just secure the tube in it and cut a couple holes so it would stick out on either side. This would mimic my current setup but remove the need to attach the tube to the frame or camper body (as it is now with my floorless/backless plastic tub. Assuming the trough is indeed wide enough, does anyone see a problem with this approach?
    @ScottG, the trough is wide enough for 4 plastic Camco stabilizer jack plates to fit in the trough. I can’t can’t answer the other questions yet.
    Do you have the commercially made sewer hose holder?  I have one I can use to see how it will or can fit.
    edited January 2021
    @ScottG, the trough at the top of its front lip is 4 3/4” wide.  I will share photos. If you need more, please tell me. The T@B is just outside the garage.
    Four stabilizer Jack pads fit easily in the trough. 5 are too tight to fit well.
    Just to give you an idea of one of the longer Valtera tubs and it’s length across the front. (I’s just laying on top of the tub.
    It is in the 30’s here, but this is how far the lid goes up with the gas strut inside stopping it at this point.
    I have the Boondock model and it is in the way to really show you the lower left side of the tub.
    This photo shows how much room is at the side for the Valtera tube.
    Thanks, @Verna! I have the standard Valterra carrier. I don't recall the exact O.D. but I think it may be a little chubby for that trough. I suspect clearance to the camper wall might also be an issue.
    I might take you up on the offer of additional photos once I ruminate on it a bit more.
    @ScottG, I think the trough is intended for the sewer hose only. I have a couple of 5’ sewer hoses that I can put in there and photograph. Tell me when you’re ready.
    @Verna (or others). A photo from the front looking into the tub at the back wall would be helpful. It seems like the trough extends into the curved area at the lower back, and that there is some sort of partial partition behind it, but I can't quite tell from any of the photos I've seen. Thanks!
    Here’s 3 more photos, @ScottG
    I finally had some help yesterday to move my batteries into a battery box, so it will look a bit different than the first photos.
    There is a full back to the new style tub, with two holes cut out—one hole for the battery switch and the other for the propane regulator.  This is looking behind the left corner of the battery box, in the middle of the tub.
    This is the far left of the tub looking down behind the propane tank. The water drop you see is on the floor of the trough. You can see the gravel driveway through the hole in the back of the tub, plus part of the propane regulator.
    Until yesterday, I thought the tub’s floor was solid, but there are holes here and there, at least one large enough to run a propane hose through it. So, if driving on gravel or dirt roads, don’t be surprised to have dust inside this tub.
    If you want to see the photos full size, Scott, I can email them to you.
    Thanks, @Verna. It's starting to make a bit more sense. Is the back wall sloped or curved in some way to maximize the space, or is it perfectly plumb? In the photo below (from another discussion) it looked like the trough might extend into the lower curve of the trailer. Hmmm, but now that I look more closely at it I'm not so sure.
    edited January 2021
    It extends back towards the curve bit, so the tub is wider at the bottom by a few inches over the top area.  The back wall is still flat, but slanted back under the curve, think trapezoid.
    @ScottG, my tub is 1 1/2 woman’s fingers from the front of the T@B’s Diamond plate front. The back of the tub slopes down at an angle, but it does not follow the curve of the front of the T@B. So, it slopes at an angle, trapezoid (per Denny 16) is a good description.
    My thought is that you may need to move your tub out a bit from the front of the T@B so that you will not lose the stability of the front lip of the trough. You will lose part of the stability of the bottom of the rear wall as that will have to be cut in order for your tube to fit.
    Got it--thanks Denny16 and Verna!
    In lieu of being able to actually see one at the moment, I think I have a better sense of how the new tub is configured. Verna, I think you addressed the key point of my question--I probably wouldn't be able to install my tube in its current location without some serious modification, as the back wall looks like it might be right where the tube needs to go.
    To be continued...
    @ScottG, is there room for you to hang the tube under the tongue, towards the rear of the tub?  I don’t know where your cross-piece is for the front of the body. Just a thought. I’m not sure about ground clearance for your T@B. Last resort is the right side of the tongue as it stays out of the way.
    Back to pondering options...
    I don't think there is room underneath to hang the tube as the dump valves would be in the way even if there was sufficient clearance. Side of the frame is an option but I'm still not ready to concede to that yet.  :-)
    Another thought is to install one of the old style Boondock aluminum tubs. It sounds like they might be just enough larger to squeeze that second battery in, while still providing the lower back clearance to keep the tube in its existing location..
    Anybody know if those are still available as a replacement part from nuCamp?
    @ScottG, watch for one for sale. There was one in the Carolinas for sale, cheap, but shipping is expensive.
  • Basil48192Basil48192 Member Posts: 436
    edited January 2021
    @Verna, Can you tell me where you found the double wide battery box shown in the photo above?  I have found extra-long boxes, but nothing in the double-wide.  Also, did you end up having to move your propane tank to fit this battery box?  I've seen some posts describing the need to cut the brackets and move the tank closer to the passenger side of the tub.  Thank you in advance!
    https://allbatterysalesandservice.com/catalog/product/view/id/16094/s/century-plastics-heavy-duty-battery-box-holds-2-6-volt-golf-cart-batteries-gc-g/category/760/
    @Basil48192, this is a very sturdy battery box.
    I have the 2021 T@B 320 Boondock, so I have the new elongated version of the front tub. One propane cylinder, the dual AGM battery box plus some misc “stuff” also fit in the tub. The dual battery box fits just fine without moving the propane tank support.
    @Verna. Thank you!  This is perfect!  I have the same tub (2021, 320S...not BD) and this is exactly what I was looking for.  Thanks again!
    You are very welcome!
  • ReenieGReenieG Member Posts: 283
    edited July 19
    Verna said:
    Are you happy with those straps? I'm debating how to anchor the same box in my new Sea Biscuit Center Tub. FWIW, I found the same battery box BEFORE finding this discussion thread. When I did a search for buying it, I found your discussion here. I don't have 2 6v batteries, but 2 mini 100ah lithium batteries with bluetooth that are the same size as my old group 24 lead acid marine battery. You're link above to the box is broken. HERE's a current link and where I bought the box in case anyone is looking.
    @ReenieG.  I am very happy with the box and straps.  I now have two Group 24, 12V lithium batteries in the same box and they fit fine.  I actually had a little room to spare, so I tucked some foam insulation between the two batteries to keep them from rattling around.
    Because I wanted to mount the bus bar and shunt on the back wall of the tub, I ended up cutting the height of the box down about an inch (used a table saw).
    edited July 19
    @Basil48192 great! Thanks for the pic. I also have 2 mini lithium that will go inside that box. They're group 24. Do you have an inverter installed somewhere?  If so I'd love to see a pic or a link to your installation discussion .
    @ReenieG.  Sorry, I don't have an inverter.  I've been boondocking (mostly) for nearly 6 years and haven't really felt that I needed one.  However, I have considered getting a small 'Jackery' type unit for the rare occasion that I might need 120VAC.
    edited July 19
    I just received my battery box today and the box and batteries fit great in that space!
    Now, the next step is to install the box.
    edited July 21
    @Basil48192 What is the controller mounted to? And do you have any more detailed pics (maybe different angles or closeups) so I can see what it is you've mounted and to what? That would be helpful for my project which I'm still sorting out.
    I have 2 EcoFlow solar generators. The larger one I have is the similar to THIS one that I have, pics below of the specs on mine. The other one is a much smaller one that I've had for about 5 yrs.
    The problem I've found, once they are discharged, there's not a really good way of charging them without 120w shore power. They charge miserably on 12v DC and not much better on solar hookup.
    So, my idea is to be able to use my 3-way Norcold fridge on 120watt would work with the inverter as well as possibly a short time of the new Midea AC. I have added an additional rooftop solar panel so it charges my 100ah battery well and now I'm adding the 2nd 100ah lithium battery and I'd like to be able to use all of that excess power I will have and can generate. The inverter will allow me to do that.
    I typically camp for 5 days or longer and most of the national parks and blm areas don't have any hookups.
    My EcoFlow Delta:
    My EcoFlow River Pro:
    @ReenieG
    The white plastic is simply a cheap, plastic cutting board that I trimmed down to fit the space.  I mounted it to the aluminum, square frame on the storage tub.  It was 1/2" thick, so I drilled and tapped holes into it to attach the solar controller.
    On the back of the tub I mounted a negative bus bar, and my battery monitor shunt (inside a cheap, plastic box).
    All of the aluminum is relatively thin, so I bought a threaded insert tool from Harbor Freight.  It basically works like a large rivet gun, but fastens threaded inserts to thin sheet metal.  It worked great for fastening all of those items to the aluminum.  I don't like sheet-metal screws in aluminum.
    45 Piece Threaded Insert Riveter Kit
    Regarding your battery situation:  I have the same battery capacity, but I have the 2-way refrigerator.  I've heard that the 2-way uses less power than the 3-way...but I don't really know.
    I do know that with 200 AH of battery capacity, I can camp just about indefinitely....as long as I get decent sun at least every other day.  During my last trip, I was out for 5 days.  I ran my refrigerator continuously, lights, water pump, fan, etc. as needed.  I would consume about 23 AH per day.  I have a 105 watt solar panel on the roof and a 200 watt suitcase.  Because we had very good sun, my batteries were back up to 100% by mid afternoon every day.
    edited July 23
    @Basil48192 Here's a closeup of @Verna's pic. I can't see the bottom of your box nor can I tell if these are the screws that come with. Did you use the ss screws that came with the straps? If not, what did you use? TIA
