Proposed tent idea
NovaTab
Member Posts: 91
the specific ones made for the tab's are very expensive and some companies don't even make them for the 2021's
But the only reason I see to get one of those is to have the door open into it avoiding the rain etc.
I looked at reviews on a bunch of them and for $180 ordered this one here
THe reviews on you tube are very good one person has it in use 8 years, look at the specs below image
- Convertible screen room with inverted "T" style door and inside flap zippered windows
- Removable seam-sealed fly
- Mesh roof vents, 2 zippered side windows with inside flaps
- Shock corded fiberglass roof frame with steel uprights and corner elbows combined with pin & ring for easy set up
- Guy out vent at the back of the tent, Two convenience pockets
2021 TaB 320 Boondock, Gran Cherokee TrailHawk
The 2021 TaBs use the same tent accessories as the previous models, the outside size is the same, as is the Keeder rail setup.
@Denny16 - PahaQue has not made a tent yet that fits the 2021 320 model. Maybe an issue with the new Keder rail.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
You could almost park the T@B inside that and still step out into your screen room. ;-)
I can't speak for that brand, but I camped in a similar but smaller version of that style tent for many years before getting the T@B.
The biggest limitation I found was that even my smaller version was so large it was often hard to find a level spot to pitch it, and it barely fit on most platform sites.
It was a great tent. Regardless, I got a T@B in large part so I could stop futzing with tents. YMMV! :-)2015 T@B Max S (320)
My last tent before I bought the Tab was from an English company called CampingWorld UK. In Europe they have whole lines of tents designed for "caravans". They also have many other designs for tents with "vestibules" that allow you a place to "hang out" if you want to be outside, and extend the space of the camper.The tent looked like it would be the perfect addition to the trailer, but, alas, it didn't make it through a windstorm and really didn't make it through the clinical trials. This is just the page to the "awnings" for the "caravans", and on a quick look, some even have keder rail functionality. But a lot of these look interesting, especially the inflatables.Here is a Dometic inflatable "awning" that has a keder rail.
Towed by 2014 Touareg TDi1
