The Alde is not getting power when plugged in but either are the gfci switches. I tried resetting the one in the kitchen and the one in the bathroom, I am plugged in to shore power at home. The circuits don't look blown- I already changed the barrel fuse in the Alde and the one in the fuse box- they had both blown but I think I might have had the Alde on when I plugged it in recently.
Any suggestions for other things to look at?
0 ·
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
If you are currently using a surge protector, consider removing it to eliminate a variable.
Inspect the 30 amp plug. Are you sure you have turned and locked it into position?
Just to make sure the TaB AC breakers have not partially tripped, turn each AC breaker switch on and off.
Experts, chime in please.
2020 TAB 320 S Boondock Lite
2019 Toyota 4 Runner
Puget Sound Country
