Hello ... I am taking delivery next week of our new T@B 320 S Boondock. After spending countless hours in this forum and online with videos etc I am trying to determine what I really need (or don’t) to begin our adventures. The salesman’s advice is “try it a few times before you start buying” which seems like good advice. However I know that there are some essentials (example water hose) that I do need to consider. I have been keeping a list but I really don’t know what would be considered the basic “must haves.” I would appreciate any guidance! Thank you
2 ·
You are right that you will want a potable water hose if you plan to camp with hookups. You will also need a pressure regulator for said hose, as well as sewer dump hose, but my T@B came with cheap but serviceable versions of these last two items, as well as a decent 30A RV power cord and 15/20A adapter. If you plan on dry camping (i.e. camping without hookups) a jug to fill your water tank is useful.
You will also want something to chock the wheels, and in many cases level the camper. There are a host of fancy options but I've gotten by for six seasons with scrap lumber.
When I started, that was the extent of my added equipment--I bought little else that first year. I should probably admit I knew very little about RVing at the time, but ignorance was indeed bliss and I survived nicely. :-)
You will of course need the galley bits and bedding, bathroom stuff, and RV toilet paper or a good quality one that is approved for septic systems.
This should get you started. Happy camping and welcome aboard!
The "must haves" really depend on how a person plans to use their T@B. What kind of camping do you plan to do @Bclarke?
That said, if you are conservative with power usage and drive long enough between stops to recharge you battery (and your tow vehicle is capable enough to do so) you still may be able to get by if your stays are limited to a night or two.
If you’re going to Boondock, the single most important "must have" is a way to recharge your battery. Do you have a plan for that?
If possible, I'd try camping in the trailer in your driveway or a nearby park for a day or two to figure out other must haves (cooking, comfort). Many of us find that the stock cushions are too firm to be comfortable for sleeping. Some people use a foam topper, some people use Thermarest style self inflating mattresses. If your wife is not fully on board I'd figure out the comfort thing PDQ.
Here are a couple of lists that I've been putting together. They're not comprehensive - they are just things that I have purchased that worked for me. (Disclaimer: I get a very small commission from purchases through these links, but feel free to shop around and get the best deal for yourself).
T@B outside stuff
T@B inside stuff
Other T@B stuff
Regardless, a 2-way fridge will generally still draw more power than 3-way on propane. The pros and cons of one vs. the other have been debated here in other discussions--if you a do a search you can probably get more insight.
Tampa FL
