Any thoughts on replacing an existing wet cell, group 24 battery with an equivalent lithium battery, such as:
https://www.lynaclithium.com/product/12-8v-100ah-true-series/Here's a related article:
https://rvdaily.com.au/12-pros-and-cons-of-lithium-batteries/                2014 T@B 320 S "Sunny" - 2015 Toyota Sienna LE - British Columbia, Canada
0 ·
I’m planning on swapping mine once my current AGM is ready for replacement.
https://tab-rv.vanillacommunity.com/discussion/12574/dead-battery-2014-t-b-320-s#latest
SF Bay Area
Update: replaced a blown fuse on the Alde and it’s all systems go!
We no longer have to worry about getting electrical sites.
2016 T@b Q
Lakeville, MN
2012 Jeep Liberty KK a/k/a "Libby"
2016 T@b Q
Lakeville, MN
I'll try to pull together some info and see if I have some photos. I followed a box install by member Klenger. Unfortunately, he no longer has a T@b and the web page no longer works.
2016 T@b Q
Lakeville, MN
I bought a lithium-compatible battery charger/maintainer. It has an outside air temp reading and is a smart charger. Should I hook it up to the battery when the T@B is in the driveway? This is the model I bought:
https://www.amazon.ca/gp/product/B08NVG5ZT3/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
It's a debate because the lithium batteries do not magically 'create' power, allowing you to use more. They are simply vessels that store power. There is something else at play here - like increasing the storage capacity and adding additional or more efficient charging equipment. There is nothing special about lithium, except for the outrageous cost.
So while a 100 amp lithium does not hold any more power than a AGM or Lead Acid 100 amp battery, you will get to use more of that 100 amp hr of power, as you can discharge the lithium down to 10-15% of its full charge level, vs 50% for lead acid and 60-70% for AGM. At 60% discharge level, the lithium is going to have a higher voltage reading than the other two also, giving you more useable power.
