I know this topic appears in the Forum regularly and I have read through several past threads. Lots of answers but often completely different. Last month before picking up our 2021 T@B 400 BD I asked the dealer about installing a sway control bar based upon our Toyota Tacoma owner's manual statement that towing a trailer over 2,000 lbs required a "sway control device". They didn't think it was needed but agreed to install one. Day of pickup the technician conducting the orientation told me sway bars could not be installed on the T@B trailers due the C-channel A-frame construction which would be weaken by drilling the holes required to install the sway bar. After much discussion I gave up and drove home 175 miles with no "sway control device". I never experienced any noticeable sway even in high winds.
Given the owner's manual stated requirement for a "sway control device" I am still considering installing one. Have any other T@B 400 owners experienced or heard of any issues with drilling holes into the frame to mount sway bars? Does anyone know if Toyota's anti-sway feature, that is part of their tow package, meets the sway control device requirement in the owner's manual. I am also going to ask NuCamp about the frame drilling and Toyota about the tow package's anti-sway feature but am hoping other owner's have already successfully resolved these questions.
SW Colorado
1 ·
I've also emailed NuCamp Technical Support whether they have a position on whether drilling holes in the frame is a problem.
SW Colorado
SW Colorado
SW Colorado
SW Colorado
As far as a T@b and sway I was told by my dealer, the install of sway control isn’t an issue with the frame. But the installation of WDH(weight distribution hitch) is.
And all this was in relation of a 320.
Odessa, Fl.
I didn't install sway control or weight distribution on my 2019 T@B400 pulled by my 2017 Nissan Frontier (6000 # towing capacity) similar size to a Tacoma, and I occasionally notice a very small amount of sway. When towing I rarely exceed at 60 mph which reduces sway and helps my gas mileage. Someone posted somewhere on this forum a video of how trailer loading can dramatically affect sway. I will take my loaded truck and trailer to a scale to measure each axle weight and tongue weight to be sure it is all appropriate.
Southern California
Full-timer since 2019
SW Colorado
I got urethane sumosprings to prevent tail sag but that's it.
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
SW Colorado
so you have front & rear TV then trailer.
that will not only help any sway weather you feel it or not but improve overall handling
PS: some TV's have built in sway senors like my Trail Hawk
https://www.etrailer.com/Accessories-and-Parts/Reese/83660.html
2018 Toyota Highlander, XLE
Wisconsin
Odessa, Fl.
SW Colorado
SW Colorado
Also mentioned is loading and speed, so load properly and slow down and sway control probably will never engage.
device with sufficient capacity is required." Does that mean I need an add on sway device separate from Tacoma electronic system for a 400 Boondock? I guess I have to try to contact Toyota and try to get an answer. I'll be pleasantly surprised if Toyota will give me one.
I did a fair amount of research, and got the impression that TRDs sag more because of their nice off-road suspension. I also read about the SumoSprings, and went ahead and installed them before I even got my T@B (so I never towed without). The first time I hooked up, though, at the dealer, I watched the frame come down onto those springs and definitely compress them! With the springs, I sag about an inch.
Honestly, I never thought about the warranty. The springs replace a dinky little pyramid-shaped rubber pad (with metal base) between rear axle and frame that's held onto the axle by the U-bolts. It's a very quick install and the only touchy part is making sure your U-bolts are put back on in the proper position with proper torque.
Driving without the trailer, I never even notice the SumoSprings are there.
Hope this helps!
So the question becomes, how much margin of safety was put into the beam design/selection to account for corrosion, accidental dings, etc so that the beam can carry the load with normal wear and tear on the beam. Since we're not reading a rash of stories about beam failures after installing these devices, the margin is probably sufficiently high, but it ultimately comes down to what the manufacturer says.
PS: I am a mechanical engineer (retired).
