Someone on the Forum posted some computer drawings showing the aluminum frame locations in the exterior walls. Please provide if you know where they are.
2016 Outback 320 2024 Ford F150 Supercrew short bed.
The exterior walls are Azdel/foam/fiberglass composite. Only aluminum framing is around the outer edge and around the windows and door openings, as shown in the PDF Bayliss posted above. Not sure what you want to do. cheers
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
Yes! Thank you Bayliss and Denny - those are the drawings I was referring to. Thanks also Crab T@B for responding to my question. The door sidewall is what I was interested in. It looks like the screws holding the wood valance go into the Azdel - not the aluminum frame around the window. Will not be attaching anything even remotely heavy to the wood valance(s).
Clarification on Aftermarket Roof Rack Installation (vanillacommunity.com)
2019 320 Boondock Edge - Sold Jan 2022
https://tab-rv.vanillacommunity.com/discussion/8012/grab-handle-for-2018-320s/p3
Not sure it is what you are looking for, but I have attached an additional document here as well.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
