We have a 2021 Tab 320 CS-S Boondock on order. Our dealer contacted us to see if we wanted to upgrade our standard battery. We are very interested in the Battleborn LiFePO4 Lithium battery, but the dealer said they do not install lithium batteries as an option. We are considering getting the standard battery, but then upgrading to the LiFEPO4 on our own. Will we have to get a new lithium compatible power converter? Battleborn says we don't; that you just switch out with the old acid-lead battery, but we would like to know if others have had experience doing this. Also is the lithium battery compatible with the factory-installed Victron Smart Shunt battery monitor with Bluetooth? TIA for any help!
Lewes, DE
2021 T@B 320 CS-S
2020 Toyota Takoma
0 ·
2021 T@B 320 CS-S
2020 Toyota Takoma
I went with 2 6V AGM's mounted inside under the bed next to the charger with their weight over the axles. They fit perfect.
Now I can add a second propane tank in the tongue box.
I added two terminal blocks in the area of the existing battery then ran 2 #10 from them under and thru the wheel well. I used a piece of pex pipe as conduit.
Brad
Concord, NC
Temperature
High temperature: > 135F
The BMS will not allow a charging or discharging current.
Low temperature: < 25F
The BMS will not allow a charging current. Charging current will be allowed again at 32F
The BMS will allow a discharge current down to -4F before shutting down.
I would recommend this video from Will Prowse interviewing the BB CEO. I had to listen and take notes a few times to get to the important points for me: https://www.youtube.com/watch?v=ywn-vBjKblI&list=WL&index=4
He discusses the hot/cold factors, charging, float, and storage.
If I'm depending on the battery for power, I'm dry camping and I'm recharging it via solar and the converter isn't a factor. If the solar doesn't keep it topped up (winter or bad weather) then I put the battery on a charger when I get home (I don't have rooftop solar). If I had rooftop solar, it would top up the battery while the trailer's parked. What's the hurry? What's the "need" for a faster recharge?
If I'm camping with hookups, I'm not depleting the battery, so again, what's the "need" for faster recharging?
Under what scenario do you want or need faster charging from the converter?
Hope this helps!
Brad
Concord, NC
Brad
Concord, NC
We've been stuck in the desert in super hot temps but again Battleborn says it is protected up to 135 degrees.
So I added 74.6 lbs. of CCC at only $2.68 per lb. Kind of expensive when you look at the cost per pound.
Brad
Concord, NC
I assume the GC2 is meant for someone who has existing 6V GC batteries and just wants to replace what they have, but its really not clear from their website or from reading.
I know someone here can fill me in on which to purchase.
Golden, CO
Brad
Concord, NC
