First time wash/wax Tab 400 BD 2021
Simbionic
Member Posts: 36
Need some detailed info about recommended products, tips, tricks etc re washing/waxing. I comm'd w Creed, the tech at NuCamp as well. As usual they redirect to the Forum. He did say using dawn dish detergent is ok to wash exterior. (I have a friend who says its not good for the finish(??). Creed also recommended Maguire's wax (NOT POLISH!).
What are people using that works well without deteriorating exterior elements or affecting factory striping/decals.
Is using an electric orbital buffer ok?
How to remove the dark streaks, ie below windows? Another rv user said use Awesome Orange, but when I went online to read user comments, they were quite mixed, with plenty of warnings and cautions.
Since the roof is aluminum(??), should a different waxing product be used vs the sides?
Is Simple Green an acceptable spot treater?
Very open to advice!
Simbionic
Tab 400BD
TV: 2013 Lexus GX460
Tab 400BD
Without doing much prior research, I used a car wash soap diluted in water and a long-handled soft brush to clean the exterior. It took some time to reach all areas, as I was up and down a ladder consistently.
Once it was clean and dry, I used a car wax with an orbital polisher.
I did this in October before putting the trailer into outdoor storage. It’s nearly March and the trailer looks great. Water still beads off the exterior. Unless I learn that this process is not recommended, I will do it annually.2020 T@B 400 Boondock Lite.
2020 Chevrolet Colorado ZR2
with the 2.8 litre 4-cylinder Duramax diesel.
The roof is aluminum with a clear coat. Any car wax will work. I use dish soap on my cars. (Internet runs screaming from the room).A thread about streak removal. https://tab-rv.vanillacommunity.com/discussion/5952/stain-removal-from-white-exteriorAnd, more than you asked for. Washing your trailer is about the same as washing your car.
Towed by 2014 Touareg TDi1 -
How did you wax the roof? Is it safe to crawl (195 lbs) onto the roof?Simbionic
Tab 400BD
TV: 2013 Lexus GX4600 -
Onto the roof, no. I just used a sponge mop, either with a sponge filled with a little liquid wax. I've also applied paste type wax to a microfiber towel, wrapped it around the mop head, and waxed away. Not easy to remove the dried wax in the middle part, though. I don't worry about it too much.
There is a do it yourself car wash near my storage place with tall bays. I just take my 320 there and use all their brushes, soaps and waxes. Next time I might bring a small step ladder to access the roof with the brush better. Has worked great so far.2019 T@B 320 S | 2019 Subaru Ascent0
We do that when we travel. Hauled west in March to Utah and hosed off in Oklahoma!Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
When washing the T@B, what do you do about rooftop solar panels?0
Use a soft brush and a mild soap solution or a pressure washer set on low, and give them a go...
DARK STREAKS BELOW WINDOWS:
Someone recommended a product called LA's Totally Awesome, and sure enough I found it super cheap at my local Dollar General. Spray it on, let it sit a minute and then rub. Amazing!!- Virginia
- 2020 T@B 400
- 2018 Tacoma SR V6 3.5L
Be careful with the Awesome. The stuff in the spay bottle is diluted, the stuff in the pour bottle is full strength and needs to be diluted according to what you want to use it for. There are mixture suggestions on the bottle.warbler_road said:DARK STREAKS BELOW WINDOWS:
Someone recommended a product called LA's Totally Awesome, and sure enough I found it super cheap at my local Dollar General. Spray it on, let it sit a minute and then rub. Amazing!!2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL1 -
Be careful with the acrylic windows. Use a spray cleaner for acrylic and no paper towels. Inside and out.2020 T@B 400 "OTTO" (build date 08/19)
San Diego, CA
www.airbossone.com
https://fineartamerica.com/profiles/owen-ashurst/shop0 -
@AirBoss I have learned the hard way that the devil is in the details. I haven’t washed my windows yet because I didn’t know what to use for acrylic windows. Question, would I be mistaken to use Rolite Plastic and Acrylic Cleaner as it says it also “polishes” leaving a repellent surface?2021 TAB 400BD; 2015 Audi Q5
Boston Northshore0 -
@Katydid, just check to confirm that it is OK for use on Lexan. I purchased "Plexus - Plastic Cleaner Protectant & Polish." It indicates that it is good for all types of clear and colored plastic, including Lexan and other acrylics. I haven't tried it out yet (my trailer is still covered in storage), but I believe others on this forum have used it. It says to use a clean cloth, but not paper towels.
One warning about using public self-serve car wash sites. The dirt/grit on the brushes used by others to clean their vehicle can scratch the Lexan acrylic windows on your T@B.2019 T@B 320 S Boondock Lite ~ 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ)1 -
Our dealer recommended Sprayway Glass Cleaner and a microfiber towel for the black streaks and it works great.2022 Tab 400 Boondock
2024 Toyota Tundra SR50 -
Check with the campsite host/manager before washing your trailer at a campsite, some places do not allow this.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0 -
My neighbor brought me a bottle of Turtle Wax Ice one the day after I had finished washing my truck. He told me to try it. This RV wax is the best spray wax you can buy, period!! You only have to use a couple of sprays per quarter panel for a deep glistening shine second to none!! Goes on easy and comes off easy with your microfiber towel. This will make your vehicle look wet after you use it!
This RV wax has lubricity agents designed to promote ease of application. It also makes use of a sturdy formula in the sense that it beads longer when compared to ordinary wax. It tends to spread unevenly when you first apply it, though but after that, it will eventually even out and lose streaks.0
- 418 Service/Maintenance & Recall Notices
