So, I am over the moon happy with my two six volt agm batteries (in the storage tub by the propane tank)... seems like an endless power supply after the 12v lead acid battery.
I have a minimalist setup - my TV is a RAV4 Adventure, with a tow capacity of 3500 lbs and a max hitch wt of 350 pounds. With my new batteries and a full load I’m getting uncomfortably close to 350 pounds. One of my first mods was to move my spare from the factory rear under mount to the front jack post. Now I’d like to move it either into/onto the TV or as counterbalance on the back of the 320S. All of the discussions of post-factory roof rack installation make me think: expensive, finicky, not terribly useful. I think I’d be happier with the absolutely simplest way to mount the spare on my 2018 Toyota factory installed roof rails. By the way, I know I double the effect of relocation by mounting the spare aft of the T@B axle, but that isn’t compelling for me.
Sage advice, my dear fellow travelers, requested.
I see you have the same make/model. I am in T@B love, by the way... although it doesn't take long to realize that the spare can't stay under the rear frame! a Simple solution would be nice... successfully/carefully mounting anything into the roof framing slats is... scary. Let me know if you find a good solution. I wish i could mount it just UNDER the bumper on the down slope curve.
