What size Generator do I need for a 2021 320 S Boondock with the Aire 8 A/C?
RHW
Member Posts: 4
We bought our T@B in the fall. We plan to use it this summer and want to purchase a generator for boondocking and being able to run the A/C. Please share thoughts and recommendations for the size & type generator to buy. Prefer invertor & dual fuel so I can use propane and NOT deal with gasoline. Thanks!
Towed by 2014 Touareg TDi -
Probably a 2000w works fine, it does (or at least a Honda 2200i) ok with a CoolCat and I think they are a bit more power hungry than the Air8.
Some brands can be easily converted to propane only and that is what I did with my Honda, but I think conversion kits are generally only for Honda, Yamaha, etc. Known names.
The big player in dual fuel seems to be Champion.2019 T@B 400 Boondock Lite -
I ordered the Pulsar 2,000/2,200-Watt Dual Fuel Gasoline/Propane Powered Inverter Generator. I'll report back after we get it and try it next month. Thanks for the responses!
RHW said:I ordered the Pulsar ... I'll report back after we get it and try it next month.Looking at the Pulsars PG2300iS. How did your purchase work out for you (or anyone else).
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
