There have been lists of discussions of towing a TaB400 with small SUVs and Jeep Wranglers. A TV that is too light or being pushed to its limit towing a trailer like a TaB400 is a bad idea to start. Also having a TV with too short a wheelbase can end up in an accident, as well as towing too fast (more than 60mph) when you are at the max limit of your TV.
A vehicle’s max tow rating is based on towing an average trailer, not a big boxy Travel trailer.
Here is an example ave a max frontal area rating which also has to be taken into account. A RV also has a larger side surface area, which can catch side gusts of wind and create a roll over. You need to take the TV size, wheel base, and weight/mass compared to the trailer being towed. It is more than just the trailers GVWR and tongue weight. A TV needs to be able to handle the mass/weight and any wind loads on that trailer. The shorter thenTV wheel base, the less control that TV will have on a given trailer.
Here is an example of what can happen when you are towing a trailer the size and weight of a TaB400 with an undersized TV, in this case a Jeep Wrangler
4-door JKU ( (actually a 2-door, short wheel base Jeep Wrangler). Even a larger 4-door JKU or JLU would be overtaxed by this trailer load.
Note this ends badly: https://youtu.be/8nNpf-jYWdg
Something to think about before you hitch up a large trailer like a TaB400 or a small TV. Happy travels and please be safe...
2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
1 ·
I had three of those TJ Wranglers over the years, all six cylinders with manual transmissions. They're rated for towing 2,000lbs, and trailers with a front surface area under a certain square footage, I don't remember exactly what it was. I've only towed small, low-profile utility trailers with them, always kept them under 1,000lbs, and always used an anti-sway setup. Person in this video is an idiot, and lucky nobody got seriously hurt or killed.
PersonalIy, I would rather have a TV that can control a trailer then the trailer controlling the TV.
I know in some instances you may run into unforeseen circumstances that will tax any TV and your driving skills, but a TV that is more than adequate may save your butt in the long run.
We were lucky to already own a TV that could handle our 320 when we purchased it.
With the price of new/used TVs I can see where people want to utilize what they already own.
I wouldn't want to tow any trailer bigger than a small pop up, with anything less than a full sized truck.
Tampa FL
[A] search this forum for owner experience with that rig
[B] use web-site listed in picture below to run your own calculations
I don't understand how that calculator is coming up with it's numbers. The Ridgeline has over 1,500 lbs. of payload, 5,000 lbs. tow limit, and 600 lbs. tongue weight limit.
There is no way that the T@B 400, even with 500 lbs. of tongue weight (which is very high for the 2021 model - mine scales at under 400 lbs.) puts the rear axle over it's rating.
And in actual use, the Ridgeline tows the T@B 400 incredibly well. It's only failing is that it needs an additional 10 gals. of gas tank capacity for long distance trips. I've towed my 2021 400 over 10,000 miles with a 2020 Ridgeline and it has been flawless.
Everyone has their own opinion on what they consider adequate and safe and I stand by feeling that anything less then a full size truck is taking a chance.
To each his own.
Tampa FL
2nd: Use the web-site calculator for your specific Ridgeline & T@B model year
and your typical loading . . . while the Ridgeline is doing well you might be
pushing axle load limits (something most folks don't check)
What is most important . . run your numbers for your rig then decide.
P.S. Glad you are having a positive experience with this TV - T@B combination
It is not a 4-door JKU.
As mentioned early, if someone is willing to hook up a trailer so far outside their allowed rating, we have no idea what other reasonable precautions they did not take.
The JKU is rated for 3.5K That is not a JKU.
On the SUV vs truck topic, you don't *need* a truck, but on the flip side, you know with a truck you just set it and forget it. Much less obsessing over your car's wheelbase, tow limits, payloads, etc. - especially with a Tab. I personally don't like trucks so am holding out with a (capable) mid sized SUV as long as possible, but I absolutely get the appeal of a truck. Who knows - maybe someday..
EU/UK have longer trailer tongues, which reduce the tongue weight, and different coupler systems, which are more of a poster locking on the hitch ball. They also use surge brakes on more RV trailers than we do. The Dutchman TaB was a UK/Eu setup on the tongue and trailer weight distribution.
Also, the EU trailers have a longer tongue setup and locking hitch, which gives lighter tongue weights that we have here.
