Can anyone tell me if my 2017 T@B Tab Q Max made by Pleasant Valley Trailer co. Has trailer brakes? We are thinking we would like to buy a Toyota Sienna 2018 XLE to tow it but I can’t seem to find out for sure if my TAB has trailer brakes. Thank you in advance!! We love it and have had it since 2017.
0 ·
@Sharon_is_SAM, one of our forum moderators, tows with a Sienna. Sharon is wise in the ways of that trailer/tv combination and can give you sage advice. Good luck, -Denise
Interesting @Sharon_is_SAM - my 'used' 2014 T@B 320 S came with an equalizer hitch, similar to this. The max distance I have towed with the Sienna, so far, is 100 miles. It creaks quite a bit especially when turning corners, but feels really solid. I hope to do a longer trip soon!
When connecting the trailer, this hitch requires that I first connect the ball socket, then raise the levelling jack so that the equalizer bars are high enough to fit on the rear brackets without any tension on them. Then when I lower the levelling jack, the bars are loaded by the weight of the trailer on the hitch. To disconnect, it the reverse: raise the levelling jack to unload and detach the bars first, then lower the jack to disconnect the ball socket.
NOTE: my 2014 has surge brakes so I tow with a 7-pin connection and without a brake controller.
I was wondering exactly that: how to tell if the surge brakes are working. Sounds like mine are preventing from working by this hitch!
Which model of the Draw Tight hitch do you have?
Is there a special ball I need?
Odessa, Fl.
I'll be tracking down the correct receiver today and can't wait to try it out next week on my next camping trip
all shiny and new: 2x2", 8" shank, 2" rise, 2" ball
Odessa, Fl.
It is also noteworthy that the cutover entailed an entirely new frame style, not just the brakes themselves and that the early versions of the newer 'electric brake' frames have shown some structural issues that thankfully have not been seen, that I know of, on the 'surge brake' frames: https://tab-rv.vanillacommunity.com/discussion/comment/88271#Comment_88271
