I have to disagree in regards to the T@B. The factory has stated 35lbs. I don't own an outback but the tire pressure is related to weight not the axle or height, I would suspect the same pressures or close to it. The sidewall 50 psi is a max pressure for a max load on that tire. There is almost no chance any T@B could come close to the weight required to demand that max pressure.source3 said:Outback tire (just looked): General Grabber AT2. 27x8.5R14. 50psi. No manual for the Outback provided. Received all other manuals. The online version for the T@B shows 50psi for the other models.
Stickers (i.e. Vehicle recommendation) I use as a baseline and adjust air pressure depending on load and road surface.
Most trailer tires are 50psi as they function differently than a vehicle tire.
Do not know what to tell ya. Just checked the actual tire pressure. 48 psi. Picked up the T@B Outback two weekends ago from the dealer. Drove the trailer from Phoenix to Durango. Pressure did not feel over inflated. FYI: Been towing trailers (landscaping/utility trailers) for over 25 years so that is what I am basing my opinion on. I will be interested to see what others come up with as now I am curious.Rad said:...
Jenn, I doubt you will ever get a definitive answer to that question. There will likely be as many different opinions as there are answers. The most disagreed upon topic of any brought up in any trailer forum.
I run 45 psi in my current tires. When I first got the trailer, I ran 35 psi as recommended by the manual. Granted, they were not top quality tires, but did not take long for them to pit and wear on the outside, a definite sign that they were under inflated. My new radial tires have done great at 45 psi and that is where I will continue to run them until something proves that not to be correct.
I know you have done research on this and hope you are able to find the right pressure for your trailer and weight combination.
J.D. & Sue
PM sent.DurangoTaB said:Andrew...do you have your Outback now?
(bad pun, couldn't resist - for those of you who know the acronym).
