FB owners of newer trailers are finding glycol all over the driveway. I know there are new "bleeder valves" in different locations. Anyone know where one of these would be in a 2021 320? I found a picture in one of the threads, but Vanilla traps some threads in something called "Best Of".......and the links provided send you to...a vast wasteland of posts, and not the specific link!
2017 F-150
Coeur d'Alene, Idaho
2021 T@B 320S Boondock, Chevy Avalanche, Happy wife.
2017 F-150
What surprised me more was 4 1/2 days with Alde and refrigerator running, lights as needed, and me playing with the Jensen (connected and running well) and the LOWEST I saw the standard battery go was 12.7V which showed up as 2/3 full on the indicator panel. Very nice.
Do you know what glycol was used when they refilled your Alde with glycol? Do you know why it “dumped”?
The dealer said the glycol dumped because of a closed valve... not sure which valve. The filled it with appropriate dealership glycol and it is green. I've checked their level since and it is now mid-range.
” According to the Safety sheet the RhoGard Ultra is clear, blue. See section 9.
https://www.rhomarwater.com/pdf/RhoGard%20Ultra_SDS.pdf”
since we had bright green fluid on the tarmac, I'm now asking if they flushed the system or just topped it up. Mildly concerned here.
Thanks for flagging this. and to @Verna for the additional link.
...Doug
@Sharon_is_SAM I'm not sure of the actual manufacture date. Do you know a way to determine it. I suspect it was fairly recent though it did arrive with the green glycol.
I've confirmation from the dealership they did the recommended change in glycol for our unit. I will need to wait until I see the trailer again to check the manufacture date. Maybe later this week.
Trips - 48 Mileage - 63,452
managed by VE Smart Network
