Looking for any recommendations on when or which brand to replace tires on 2018 400 Boondock. Current tires look OK but have about 10-12k miles . Was thinking about Mastercraft Courser MXT. Any thoughts? Thanks
2018 T@B 400/solar/2022 Honda Ridgeline
0 ·
The best tire you will finds in an "ST" rating is a Goodyear Endurance sized 225/75R15 . They are fantastic tires . Just had 4 brand new installed on our 32' following a double blowout on Rt95 around Jacksonville about 2 weeks ago. They towed much better , smoother, and tracked better than the stock "China Bombs" . Plus it felt way less stressful rolling on proven Goodyear trailer tires than some unknown brand . The only downside is they are not "rugged" looking for the "Boondock" look .
Sharon .........The Hankook's also do not come in the 235 size unfortunately .
2024 NuCamp T@B 400 BD, Charcoal / White
https://www.tredittire.com/tire/rainier-st-apex/
Odessa, Fl.
We just ordered a new 2022 Winnebago Micro Mini , and they are lifted and have that "Boondock" look , like the T@B's . They are using a WestLake CR857 . They are about the same specs as the Rainier's and have that aggressive look as well .
https://www.etrailer.com/Trailer-Tires-and-Wheels/Westlake/WST54FR.html?gclid=EAIaIQobChMItuOqqsj47wIVqRitBh1_cQBSEAAYASAAEgKVqfD_BwE
Tampa FL
Its the Boondock size of 235/75r15 that is mostly the problem . The Goodyear Endurance on makes a 225/75r15 for a replacement size .
Our tires also looked perfect , but were getting older . We gambled and lost . Had 2 blowouts 15 minutes apart on RT 95 around Jacksonville FL , about 2 weeks ago . This was on our larger 32' RV . Was not a fun day ! Should have had those Chinese crappy tires replaced with the Goodyear Endurance's before our 2200 mile trip . Live and learn .
I would highly recommend replacing those 4 year old tires for some quality GD Endurance tires . You wlll feel SO much more at ease while towing with new GD tires on the RV . You only have 2, so the cost wont be too bad . Also, because you have only 2 ........having a blow out would be VERY bad with a single axle trailer . Luckily we had a dual axle RV when ours blew .
