Maybe, but I'm not sure it makes a difference as you are still dealing with those high points. Perhaps without the check valve the act of draining the boiler would in effect syphon out the glycol tapped in the convector loop. Moot point, regardless.ChanW said:I think the check-valve in the system prevents half the system from draining.
Ach! I neglected to show the check-valve.
Denny16 said:............ You could get a 3-gallon bucket, add a hose barb fitting to the bottom of it and connect this hose to replace the connection from the reservoir. Then you have 3-gallons to allow the Alde pump, set on high and continuous, to pump from the 3-gallon bucket of new fluid into the system. with the return line to the reservoir connected to an empty bucket to collect the old fluid. This would be a one person setup.cheers
@ReenieG, to clarify, the circulator pump draws from the reservoir and pumps away from the low point drain. If the drain were open and the pump were running, you would indeed be sucking air into the pump and trying to push that air through the entire system in order to push the trapped glycol out via the reservoir.ReenieG said:@ScottG it certainly wouldn't be "run(ning) it dry" since the whole point is to push more of the trapped glycol out. I doubt with this technique it would ever get down to dry. I suppose IF that would be the case, the question would be how the pump works. Is it simply pushing the glycol around or is it actually needing the glycol to lubricate it as it functions.
@ReenieG, look at the plumbing schematic posted here. There are a few errant labels that need to be corrected, but it will show you the direction of glycol flow in the heating system.ReenieG said:@ScottG I need a visual aide. I'm not good at this without a diagram, lol.
I here ya', @Bayliss, there is a lot here and I also sometimes have trouble locating specifics. My comment wasn't directed at you (or anyone else) in particular. I am glad to see this old tome generating some new interest.Bayliss said:Thanks @ScottG. I have been following this discussion since its inception, but totally missed the post you directed me to, which clearly answers my question.
Here you go @Byliss, the check valve is labeled non return valve in lower right hand corner. Without the Flo tanks, the valve is on the main boiler pump outlet. The next bit connected here is the heat conductor ( rear one for a TaB400):Bayliss said:@Denny16, can you point us to something (e.g., an Alde diagram or other reference) that identifies where the glycol line check valve is located? If not, how did you conclude/determine that it is between the circulation pump and first convector, and where, specifically?
