Power stabalizer drive.
ironshadowironshadow Member Posts: 48
I never even thought that cranking the stabilizer jacks up and down would be any kid of hardship. Until I injured my knee. Then all of a sudden I could see this becoming a chore. So today I make myself a socket that will attach to any rechargeable drill or driver. Works really slick!
    I am getting ready to hack off my extra crank handle to use with a drill, too. I don't mind cranking but when it is a 90/90 day, anything to save from getting gross helps. :)
    CyclonicCyclonic Member Posts: 1,232
    I did the same, makes the job a whole lot easier.
    Sterling, VA
    Here is an update. I kept the original handle in order. Just in case I ever forget my drill or the battery dies.
    JandJ92010JandJ92010 Member Posts: 304
    I cut off my crank handle also, than ground off 3 flats so the shaft won't slip in the chuck. Raising and lowering the jack only takes seconds. I have 3 battery drills so I just keep that one in the trailer. Forget to charge the battery? No, THAT will NEVER happen! Not to ME!
    RadRad Member Posts: 516
    The three flats, I like that idea
    JustJohnJustJohn Member Posts: 171
    Can you buy those sockets or must you make them from the supplied crank? Most stabilizers use a standard 3/4 socket but there appears to be a slot in these from the pictures.
    I just used a piece of pipe that had the same inside diameter as the original crank. Then cut two slots in one end. On the other end, I found an old 3/8" drive socket that fit inside the pipe. ( I think it was a 9mm) I tack welded it in. That gave me the right receiver for the 3/8" drive adapter.
    Thanks, I guess I better wait until September when I actually have the T@B to make sure it's all the right size.
    edited August 2015
    Ratkity said:
    You can buy them easily and they are a whole lot cheaper than modifying a crank.
    Where can you buy them, Ratkity? I'm not a welder and have far too many other hobbies!
    MercatorMercator Member Posts: 237
    Here is one available on Amazon.
    Ray and Vida Barrick
    (formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
    Toronto ON Canada
    edited July 2015
    Thanks, Ray. It's on my wish list.
    MouseketabMouseketab Member Posts: 1,230
    I used to raise and lower my stabilizers with a drill (Dutchmen T@B) and broke a "corner steady nut". I know LG stabilizers are different. Anyway, I'm now back to using the hand crank.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
    Thanks, ordered this morning.
