Using extension cord for shore power
gullystravels
Member Posts: 27
Any advise about using a heavy duty extension cord for a long reach to shore power? ie: plugging into standard trailer cord to reach a 120 outlet.
For anything greater than 20-feet, you need a heavy gauge contractors type ext cord, look for a cable with 10 or 12 gauge wire (I use a no 10 gauge Yellow Jacket cables) in a weather proof cover and sealed ends, that is 20-amp rated. This is good for up to a 50-foot run, a longer run will required a 8-gauge wire.
I use a 100 ft. 12-3 and have no voltage drop issues even when I run the AC. I am using the Progressive Industries hardwired EMS Surge Protector and can monitor the voltage under load etc. and it never complains (IE shuts down). If I were going to run the Alde on electric, the AC, and think about the microwave, yes a heavier cord would be a must but for powering the camper in my back yard the 12-3 is fine.
Brad2020 400 BDL aka "Boonie"
Concord, NC -
In my yard, I regularly extend my regular RV cord with a 75' 12 gauge extension cord to reach a 20 amp outlet. I'm able to run both the Alde electric heaters with this set-up. If you add the A/C and other devices to this mix you are probably going to exceed the amperage rating of your outlet anyway (which will in turn trip the breaker in your house).2015 T@B Max S (320)
I just use a 30 amp RV extension cord if needed.Jeannie2015 T@b S Max white with silver trim. 2018 GC Trailhawk.
thanks for all the helpful advice
- 916 Introductions
- 72 Teardrop Groups & Links
