2021 320 S Newbie Looking for Suggestions Please
happycampa
Member Posts: 3
G'Day! We just bought a 2021 Tab 320 S (not boondock). Looking for any things you wished you remembered to add to your trailer! We are getting ours from the dealer and hitting the road direct without time to think! Appreciate any advice to us newbies. Thank you!
I've purchased the following after buying our used T@B
25 foot 30 amp extension cord
Surge protector/analyzer
50 foot water hose to replace the 20 foot
50 amp to 30 amp dogbone
Harbor freight rubber chocks
Had a BAL Leveler from our pop up
Couple of tubs/containers to hold inside items like utensils etc.
Assorted tools, fuses, duct tape.
Replaced the screw on ring on the power cord with a twist on type
Tampa FL1 -
The manuals for the Alde/Fridge/ etc.This mixing valve thread. https://tab-rv.vanillacommunity.com/discussion/2676/little-hot-water/p1And, this mixing valve thread: https://tab-rv.vanillacommunity.com/discussion/5018/no-hot-water-at-kitchen-sink-bathroom-sink-had-hot-water#latestThis yellow flapper valve thread: https://tab-rv.vanillacommunity.com/discussion/10780/leak-from-rear-under-t-b-fixedThis fuses thread: https://tab-rv.vanillacommunity.com/discussion/3512/fuses-for-newbies/p1This thread about all sorts of new owner"stuff". https://tab-rv.vanillacommunity.com/discussion/9265/fresh-water/p1This thread with pictures and descriptions of the general lay out of the Alde compartment and the various drains under the trailer. https://tab-rv.vanillacommunity.com/discussion/7797/automatic-bleeder-valveA general battery FAQ. A little oldish, but plenty of good info on the bafflegab around batteries. "I Went below 50 percent SOC on my AGM" sort of talk. https://www.solar-electric.com/learning-center/deep-cycle-battery-faq.html
Towed by 2014 Touareg TDi3 -
Not my idea, but I read on this forum, that if you are picking up your T@B and do not live close to your dealer or in your case if you are "hitting the road direct without time to think!" That you camp a night close by the dealership to "shake down" your T@B.The following day have an appoint set with the dealer to address anything that comes up on your "shake down" night of camping. You can always cancel the appointment if nothing major comes up.Good luck on your maiden trip, it sounds very exciting!
2021 T@B 400 BD / 2020 Ram 1500, Northwest Arkansas4 -
Thank you!0
Sewer hose?2016 Outback 320
@happycampa - if you are a complete novice, @USSBird has good advice. Find somewhere close to the dealer to basically “driveway camp” and get your feet wet. It would help us to know what essentials you have purchased.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
