Hi all,
I have a 2019 Tab 400 Boondock that I bought last fall. I only took it out a couple of times before winterizing. We used the Alde heater just fine but never tried the Dometic. Temps were in the 50s yesterday and I decided to go out and try it out. I’d just picked it up from the dealer where I had asked them to order a couple of unrelated parts, replace the roof seals and check that the AC is blowing cold. They said it was fine. The trailer was plugged into shore power and the Alde was off. I turned on the Dometic thermostat and set it to heat mode, high fan, 75 degrees. After running for 15-20 minutes, it was still blowing cool air. Any suggestions on how to start troubleshooting this? I wasn’t happy with the service from the dealership and don’t want to take it back in if I don’t have to.
Thanks!
My initial test of the CoolCat in heat mode didn’t work either. The second try I did what I suggested above, and it worked. It takes a few minutes to get the heat coming out. Also make sure to remove the cover on the outside vent.
Brad
Concord, NC
I have the Dometic model # 441003.701 / 441003A.701
Also, and out of curiosity, is it stated anywhere in the NuCamp user manual that the Furnace function of the Dometic is not operational and to be ignored, or is this Tribal Knowledge that has been passed down via the forum.
thanks all
Only the “Heat Pump” setting delivers warm air. This was discovered and shared by forum members. NuCamp may rely on dealers to share that info.
Thank goodness for the forum! ☺️
