JWM22 will not turn off - Resolved
geoB
Our T@B 400 BD came equipped with a Jensen JWM22 "mobile audio system". Within a half-hour of its initial power up it failed. In particular, after tuning in to a radio station then pressing the power button to turn it off the radio continued to play. So I opened an issue with ASA Electronics and sent it back to be tested.
They returned it to me saying it tested just fine. So I reinstalled it and the continuous play remained. The only way to turn it off is to turn off the trailer's battery. Not an acceptable solution.
I was concerned that perhaps the device was getting too high a voltage, but it measured out to 14VDC, well within the device's 10 - 16 VDC specs.
Has anyone else experienced a similar failure? Or had any success getting a replacement item from ASA?
Thanks for listening.
2020 Toyota Highlander + 2021 T@B 400 BD
Truckee, CA, expat, now driving out of Reno
Not sure, but this may offer some clues.https://tab-rv.vanillacommunity.com/discussion/comment/164511#Comment_164511
I noticed mine doesn't turn off, either. The screen can give the appearance of being off and you can in fact power it off, but if I am inside and play music or a video on my phone, it still comes through the speakers.
Turns out the beastie has a zombie state! To turn it off one has to hold down the on/off button for a second or so. Once it displays the time it's off. Of course, unless you've already set the time, it will read 'AM 1200'.
Truckee, CA, expat, now driving out of Reno1
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
