Has anyone tried using one of those small pumps you attach to a drill to pump the new fluid into the system.
I would remove the expansion tank and attach the pump to the input side and a tube to the output side to a bucket and pump new fluid until all the old fluid is expelled. I've use one of those pumps to flush AC coils in a car before and worked great.
this thread has my procedure with a 12v pump and lots of other methods
https://tab-rv.vanillacommunity.com/discussion/2665/changing-out-the-alde-fluid/p17
This is a concern with any pump you source that is not specifically intended for "clean" transfers, so shop carefully. In some cases you may be able to clean out the excess--that is what I did with the manual transfer pump I ended up using.
2020 Tacoma TRD Off-Road
