Confused a bit about tire psi.  The label on the outside of our Tab 400 states 50psi but the tires are listed at a maximum of 65psi with associated payload (see photo) and that's what the dealer inflated them to (or nuCamp did) before delivery.  What should I inflate them to?  If I take out air and reduce to 50psi will that reduce my payload/total weight capacity to potentially some dangerous level?  We drove our unit home with no issues but as we get ready for our maiden voyage I would like to make sure we are riding safely.
The max payload at 65 PSI on the tire you picture, is above the GVWR of the camper...and I have to believe that nuCamp properly spec'd the inflation PSI for our camper's weight.
ALL ST tires should be run at max pressure checked cold, ie before daily operation commences.
Do not run tire pressure up and down chasing the thermometer, if it goes up 10psi running on a hot day, leave, it isn't going to blow, running underinflated causes heat and that may cause a blowout. A tire isn't going to magically explode when the pressure hot exceeds the cold inflation pressure by a few PSI.
ps. @N7SHG_Ham it's the factory tire as it's a new unit - so not sure who hyperinflated it (perhaps the dealer)..
The manufacture invested in the design of their product and it’s proper performance. Respect their research. They designed it that way.
2020 Audi SQ5
Although I couldn't find a detailed load/psi table for my particular tire (Rainier ST 205/75R15), I found multiple other brands that have detailed load tables and they all spec the same max load (for this tire size) at 65psi. They also line up with the simplistic spec on the Rainier website (https://www.tredittire.com/tire/rainier-st/) so I have confidence those tables can be applied here as well - it seems they're an industry standard of some sort.
These specs confirm that 65psi max load is 2150lbs, and at 50psi this drops to 1820lbs - so far so good, but is this enough?
The next step was calculating the max loaded weight of the Tab 400 - this ends up being around 3750lbs (dry weight of 2864lbs + 891lbs cargo capacity listed on the placard). Since there will be around 400 pounds on the tongue, the most the tires will ever see on a loaded-to-the-max Tab 400 is (3750-400)/2 = 1675lbs.
Based on the above, it seems like 50psi will work just fine for us, and this may actually be desirable because it will soften the ride, resulting in less wear/tear on the Tab as well as potentially less stuff bumping around inside.
Any holes in this analysis/conclusion?
My pickup has e range tires and rated for 80 psi, those I run around 60 most of the time, butbi don't do the prorated air in any of my trailer tires. Theory only, but 15 years ago on a cargo trailer I did run lower, they didn't last long and I think lower pressure might of been at least partial cause. Tire store then said full psi as on the sidewalk all the time. No issues since, running my Tab tires at max which is 50 PSI and my new cargo trailer tires at 65 psi which is the max there. My cargo trailer sticker says 50, but that was the original tires, I am ignoring that sticker now.
2017 F-150
Coeur d'Alene, Idaho
That said, most of the ST tires I've seen have a 50psi max rating. What to do when the max rating is 65psi is beyond me... :-)
@ScottG
I found the same size Rainier on Amazon, but with a 6PR instead of the 8PR of Tom's pictured tire...and it has a max inflation pressure of 50 PSI...just to add to the confusion.
https://www.amazon.com/Rainier-ST-ST205-Radial-Trailer/dp/B016DQST4S
I wonder if Covid supply issues have nuCamp using a different version of this tire with the higher Max Inflation pressure and load rating? If so, which pressure is correct for the T@B still remains open, but I think I'm now in the "inflate to the sidewall max pressure" camp.
My 400 Boondock has the knobby Rainiers, with a max pressure of 50 PSI on the sidewalls...and a 6 PR rating.
“Unless trying to resolve poor ride quality problems with an RV trailer, it is recommended that trailer tires be inflated to the pressure indicated on the sidewall of the tire. Trailer tires experience significant lateral (side-to-side) loads due to vehicle sway from uneven roads or passing vehicles. Using the inflation pressure engraved on the sidewall will provide optimum load-carrying capacity and minimize heat buildup.” (I underlined "trailer tires" for emphasis.)
I set my Boondock tires at 50 PSI cold, but I agree that somewhere between 45-50 PSI (depending on the trailer load) is an appropriate range.
There is more to the sidewall stability than just pressure. The tread of the tire needs to sit flat on a surface, and if the tire is too hard for the load it is carrying, the centre will bow out and wear out very quickly.
If I ever ran my 3/4ton truck at maximum pressure on the side wall the tires wouldn't last 20,000km. At the same time when the truck is fully loaded then I up the pressures to compensate, and lower them back to door post normal when I'm done.
There is no reason to overthink this. If your T@B is "loaded normally" like the factory expects, go with their recommendation. If you've added a whole load of recreation gear to it, then up the pressure 5 or 10 lbs. it's all good.
2021 T@B 320S Boondock, Chevy Avalanche, Happy wife.
your welcome
https://nucamprv.freshdesk.com/support/solutions/articles/44001816818-tire-pressure
In a nutshell, Creed recommends max sidewall pressure, but also says we can back off 3-4psi to soften the ride but he wouldn't recommend going below that..
It takes the worry of "I wonder how the tires are doing back there?" off the table. Both pressure and temperature are clearly displayed, with alarms for slow and rapid deflation. And while the kit comes with an easy to wire RF extender, it is not needed at all for our small trailers - making this kit just a matter of screwing on the valve stem monitors.
https://www.amazon.com/gp/product/B0797LQ44K/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
If it eliminates stress and worry it’s a good thing.
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
Sold 2023 Tab 400
Sold 2018 T@B 320S
