They are the same height as the middle tub, made of the same Diamond plate material. They also have a lock on them to protect your water and sewer hoses, Legos and whatever else you want to store in them.
They come with a triangle shaped plate to help position the tubs, plus to help give more sturdiness to the bottom when bolted. They also have a set of keys plus bolts, washers and nuts to attach them to the platform.
If you position the front of the tub about 1/2” past the front of the platform, the lid will stay up on it’s own. The pre-drilled holes give you about 1” of movement to help position the tubs as you want them.
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
2022 Honda Ridgeline RTL-E
Carmel, IN
Sold 2023 Tab 400
Sold 2018 T@B 320S
I believe I used a rachet with a 9/16” socket and a 9/16” wrench. Put the triangle plate outside on the bottom of the platform. Line the holes in triangle plate with the holes in the bottom of the box. Now keep the top open, move the box until the lid stays open by itself. Make sure the holes line up from the triangle piece to the platform.
Thanks so much for your thorough answer - I would have had it all upside down and backwards! It makes sense to have the nut inside for the reason you mentioned... My nuts and bolts did not come assembled and I only got one washer per combo... will need to google where to put that, or maybe run to Home Depot and get more - I like the idea of one on each side
Carmel, IN
