For my 2020 Tab it appears that this is supposed to be done at 2500 miles, but I'm leaving on trip in 4 weeks and can't get an appt for it in time. I'm at around 2000 miles currently and it has never been done. My upcoming trip is for 6-7 weeks and one way is about 1500 miles. I'm headed for NM and CO and by the time I'm back in NC will be maybe 3700 miles completed on that trip. Should I try and find a mobile RV repair/service place out there, or schedule something now for when I get back? How concerned should I be about the trip out and exceeding the 2500 miles before I get there?
And along those lines, does anyone have a recommendation for a service place in Santa Fe, NM? Thank you.
(Edited title for future ease of future search — Verna T@B Admin)
I have no idea how to do any of that. I suppose I can learn if it doesn't involve a bunch of tools and dismantling parts LOL. I will think about that. Thanks.
2019 Toyota Tacoma
Asheville, NC
"Don't postpone joy!"
2019 Toyota Tacoma
Asheville, NC
Along with bearing adjustment, proper lubrication is essential to the current function and reliability of your trailer axle. Bearings should be lubricated every 12 months or 12,000 miles.
2019 Toyota Tacoma
Asheville, NC
I really thought I read that somewhere. That doesn't seem like very far to me, either.
2019 Toyota Tacoma
Asheville, NC
You should learn (if you don't already know) how to check the wheels during a trip. A hot wheel or bearing is an early warning of possible bearing problems. If you are taking this to a shop for service ask them to show you how to check the bearings.
2019 Toyota Tacoma
Asheville, NC
Most folks who tow are in the habit of checking the wheel/hub temperature by hand, not using an infrared thermometer. Use the same tactic. Feel the hub and wheel after 100 miles and every time you stop. You'll get a sense for the norm. If a wheel ever get's too hot to put your hand on start thinking about a recovery plan.
Back to the bearing service....low miles but you have had the T@B for a year? Get the bearings serviced.
But, ad in the usual warnings about not mixing different grease types.....mixing greases will result in the grease binders separating and the grease running out of the hubs when it warms...yada yada...
Always use the same grease type following a re-pack... a reason I never use the alemites for the first the service...I remove the bearings, clean and hand pack with a grease I know will continue to be available and use that grease ongoing. If you have a shop do this for you have them tell you exactly what grease they used and buy some of it to use in your grease gun.
https://nucamprv.freshdesk.com/support/solutions/articles/44001817245-repacking-wheel-bearings
2019 Tundra Crewmax aka Hoss
SE Louisiana
But I'm also kinda' lazy. So, leary, lazy, leary, lazy. Decisions, decisions. You can probably predict which one usually wins. I like my EZLube! ;-)
2019 Toyota Tacoma
Asheville, NC
https://www.harborfreight.com/hand-tools/sockets-ratchets/torque-wrenches/12-in-drive-digital-torque-wrench-64916.html
2019 Toyota Tacoma
Asheville, NC
I know some folks who rotate the wrench so it's near horizontal, then they gently step on it with increasing force until it clicks. No arm strength required.
If you don't have a torque wrench, tighten to one turn short of breaking the stud
2020 Audi SQ5
