I posted this on FB, so if you’ve seen this already, sorry.
We haven't camped in a year, so we are prepping for the coming week.  The camper has been winterized for a year, so we got it ready to go.  I noticed some moisture near this valve.  Any ideas on it?  Any easy fix?  I don't see a clamp I can tighten.  Perhaps a sealant? It’s hard to determine if it’s the drain cock valve, the fitting, or the hoses into it.  In any case, it’s not obvious and not a major leak.
I want to recommend this product at Amazon
1 PIECE XFITTING 1/2" PUSH FIT FULL PORT BALL VALVES CERTIFIED TO NSF ANSI61 - LEAD FREE BRASS
by XFITTING
Learn more: https://smile.amazon.com/dp/B071YK6V3Q/ref=cm_sw_em_r_mt_imm_awdb_RVG3GMF60Q7DM8G280T4
Dale Helman
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI
The shark bite will be a bit larger, but should fit after the smaller valve is removed. You will need an 1” or so of play to fit in the new valve. If it is leaking at one of the bands it may not have been crimped tight enough. Re crimping may stop the leak. I would try that first. The tool is quite expensive but you should be able to rent or borrow one.
IWISS Combo Angle Head PEX Pipe Crimping Tool Kits Used for 1/2" & 3/4" Pex Crimp with Go/No-Go Gauge with PEX Pipe Cutters suits All US F1807 Standards
by iwiss
Learn more: https://smile.amazon.com/dp/B018VNUCSC/ref=cm_sw_em_r_mt_imm_awdb_FHPXWA7A4ZQ52YNA3WCG
Dale Helman
I was hoping it was a good excuse to buy a pex crimping tool, but it wouldn't have fit in the confined space (even after I hacked out a new access hatch), with a little reluctance I went with a Shark Bite and it has been leak free since.
@TerryV6 Photo size reduced. Moderator (Sorry, I usually downsize my photos)
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
As to whether you will have enough pipe to reconnect the new valve it's hard to say. The Shark-Bite connections seem like they might be a little longer than the barbs on a standard crimp fitting, but the bigger issue for you looks like there won't be enough pipe left between the valve and the plastic tee to properly attach the Shark-Bite. Worst case you might need to lop off the tee and replace that as well with another Shark-Bite fitting.
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
Which such limited length to work with, it's certainly worth a try to remove the old fitting and retain the tubing. The Shark-Bite replacement might be forgiving enough that it won't leak. If you try this, please report back on how it turns out.
T@bbey Road
Appleton, WI
T@bbey Road
Appleton, WI
Use another SharkBite, a coupler, to add a section of pipe.
You'll need to be able to pull the existing pipe back enough to then press it into the SharkBite, maybe ¾" or 1" insertion. Measure how deep it will go before you cut the pipe. The depth specs might be in the literature for the SharkBite.
