Failed water pump after about 400 days of service
jimcennamejimcenname Member Posts: 294
As a T@B full-timer I had my first failed component. The Shurflo water pump in my 2019 T@B400 failed me. Full Disclosure, I live in my T@B and used the water tank and pump exclusively for my water source. I've done this for about a year. I noticed over the last month or so that the pump seemed slower. A couple days ago it began stuttering briefly after I turn a faucet off. I checked the voltage to the pump. It was fine. I adjusted the pressure settings to no avail. The wire sentiment screen on the inlet was clean. FYI, I filter and soften the water I put in the tank. The local RV supply store had the exact same model pump in stock. Installation was remarkably easy. It appears to work like new. Also, I used washers under the pump mounting screws. On the old pump the screws were deeply embedded in the rubber of the mounting bracket. The washers will reduce that. I expect more than 400 days of use from a pump but in the big picture it's not a big deal. Considering my lifestyle, a tank of water lasts me about 6 days. Pentair/Shurflo warranty is 2 years from the trailer manufacturing date. My T@B's manufacture date was 11/2018. I bought it new 9/2019..
2019 T@B400
Southern California
Full-timer since 2019
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,814
    Are you sure they won’t honor the warranty?
  • WilliamAWilliamA Member Posts: 154
    I'm curious. Did you disassemble the old one? There are a couple of small pressure ports in there (in addition to the main diaphragm) that can be replaced. Perhaps they, not the diaphragm, were the issue. On my pump, nearly every spring I have to take it apart and stab away at one of them to get it working.
    WilliamA
    2021 Jeep Cherokee Trailhawk
    2017 T@G XL
  • jimcennamejimcenname Member Posts: 294
    Sharon, I didn't ask, and I wanted to solve the problem quickly. I'm leaving on a series of trips today and didn't want to deal with it during my travel.
    2019 T@B400
    Southern California
    WilliamA
    William, I did, just out of curiosity, after I installed the new pump. While there was a little slime in the old pump, it was minimal and wiped away easily. Since I live in my T@B I usually take the most certain route to solving a problem. I replaced the pump yesterday and I am departing today for a series of trips.
    2019 T@B400
    Southern California
  • BlueespyBlueespy Member Posts: 227
    James, quick question and it’s a silly one - where exactly is the water pump?  I have a 2019 t@b 400 and thought it was accessible from the compartment outside (one next to the sewer hose storage).
    2019 T@B 400 BDL
    2020 Ford F-150 XLT (V-8)
    Niceville, Florida
  • qhumberdqhumberd Member Posts: 523
    We have the 2019 and ours is beneath the clothes closet as @jimcenname indicated in the post and picture. There is a panel to lift in the closet
    we have the smaller fridge, so if you have the larger fridge it should be in the same spot but I believe access is the panel below that fridge
    I'm sorry for not responding sooner. @qhumberd is correct, I have the large fridge which has a panel below secured with two screws. That is also where I installed an accumulator to buffer the water pulse from the pump.
    2019 T@B400
    Southern California
