Hi fellow Tab owners!
We purchased a 2021 Tab 320 S last fall and have run into an issue with our Dometic gas stove. It wouldn't light when we were at 4000+ ft above sea level. It seems the gas wouldnt flow despite multiple attempts, and a lot of Googling. It was working fine up until we got to that elevation so it seems the altitude appears to be the issue.
 When we returned to lower elevation, ~1000 ft above sea level, it started to work again as per normal.
So, my question to the group is... is this normal or do we have a defective Dometic gas stove?
Thanks in advance for your advice!
(Title altered for search purposes.  Moderator)
                0 ·
I'll try to contact Dometic directly and see what they say. Regardless, I'll keep folks posted on what I learn!
Careful use of the regulator really is a thing but it seems like a long shot if the orifice is not sized properly.
I think its likely a better stove will need to be installed due to the number of people having this problem.
Customer review:
I bought this cook top to use in a van camper build. I found a review by Stewardorng posted after my purchase who said his cook top would not work above 4,500 feet altitude - a fact which was disclosed when he contacted Dometic customer service. This limitation is not addressed in the product's description nor the manual. After confirming the altitude limit with Dometic, I returned it to the Third Party Seller. My issue is not with the altitude limit; it is with the omission of the limitation in the product description and manual. I live above 5,900 feet in Colorado and will camp mostly in the mountains and would not have purchased it if I knew. It appears to be a fine product for use at lower altitudes.
I think its worth getting in touch with them to verify this.
I suppose the next step is to see what model of stove will replace the original stove.
i live at 6000 feet and plan to do lots of camping at elevation so this needs to be resolved.
My 2021 Tab 400 is stored indoors several hours away at a low elevation so I cannot test it at the moment.
It is interesting that on my first trip last winter I left from a low elevation and stayed at basically sea level and the stove worked great.
On my next trip I picked up the camper brought it home to 6000' for a 2 days to prepare for the trip. I did not use the stove at that time. On our first night in Hawthorne NV at 4300 feet the stove did not work. The rest of the story is already documented.
It seems like a call to Dometic to verify this is the next step.
Runaway30
I know this doesn't cure the issue here, but food for thought if you're considering a secondary stove for cooking outside the T@B anyhow...
2019 320 Boondock Edge - Sold Jan 2022
Verna
T@B Forum Administrator
I told them my story and they thought it was odd that the stove did not work for a week and then one day suddenly started working. Its not broken or it would not have started working they say.
For a refresher I did not have gas at the burners.
The Alde was working on gas and the bottle was full.
I swapped out several new tanks that were full no change.
I left the burners on for long periods and tried to light the burners for what seemed like hours.
When I mentioned that I had picked up the camper at sea level in warm temps and took it up to 6000' and freezing temps, his response was there's your problem.
It is clearly stated in the owners manual that the stove will not work above 4500'.
And this is proven by the fact that once we reached low altitudes and warm temps in Arizona it came back to life.
His feeling is its a combination of lack of air at altitude, and freezing temps that may affect the stoves performance. But he was quick to say this may not always be the case sometimes it may work.
So I will carry my camp chef Everest in the future, and I am curious if it happens again if warming a tank will make a difference.
I get the feeling that the stove is hit or miss at elevations above 4500. I think the right conditions need to be present to affect it. I am just guessing here but below freezing and high elevations may be two of the variables.
I find it interesting that johnfconway has had no issues at elevation. I wonder what the nighttime temps were for him.
I have a 2021 Tab 320s (we took delivery in Aug 2020). The Dometic manual says D21. I'm not sure whether it's the same model being used in the Tab 400.
Like some of the others here, I am equally disappointed that this stove doesn't seem to work above 4500' - it seems like a known design flaw/defect - and I'm surprised that it hasn't been addressed before by either Nucamp or Dometic.
In my Dometic operating manual, there is no mention of an altitude limitation and so I'll continue to press for a meaningful response from Dometic and keep folks posted.
@Verna, thanks for your message - please let us know if NuCamp is able to help owners resolve this obvious defect. When I spoke to a tech at Nucamp, it seemed that they were aware of similar complaints from other Tab owners so I have a feeling this is not an isolated issue...
SW Colorado
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
I took the trailer down to a local propane provider who changed the hose from the tank to the regulator and the stove now works above 4,000 feet! The hose is not an easy on, easy off type hose and requires a wrench to remove. No big deal. The hose has a male connection on one end that attaches to the female opening on the tank.
Since I had complained to Nucamp about the issue I let them know what is now working. Maybe they have contacted you if you have had a complaint?
The rep told me that it is a known issue but that there was nothing they could offer me to solve it. They recommended that I contact TAB or my dealer (which I already did, and they routed me to Dometic). I asked why they didn't publish this altitude issue in their operating manual if they knew of this issue but she has no comment.
@SebNick thanks for your tip. I'll look into that solution. We don't live at high elevation so its not easy for us to test until we hit the road again.
@bergger that's interesting - I'm glad it works for you. Nucamp said it was a known issue and routed me to Dometic directly...
Last week, I had the stove at 7400 feet altitude, and guess what--it worked! And yes, I did open the gas valve s-l-o-w-l-y.
Go figure.
