Can someone with this same fridge tell me if the light is supposed to glow green when plugged into electric? It glows green when on propane but I'm not seeing the green light on electric. Thank you
@Dalehelman and @lkc001 the 2017 320S the green light indicates that you are connected to shore power. Dale, my green light looks like an electric plug.
2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red
It appears that mine only has the green light glowing when on propane & flame is on— it works on electric fine— but no light to indicate that it is on when plugged in to electricity—the only way to know if it is on is to wait a few hours to see if it is cooling down— have never tried it on battery & don’t plan on it
@lkc001, we have an early 2017, build date April, 2016. We have the same fridge as @Dalehelman and @ScottG. I think the switch to the newer model Norcold began with 2017 t@bs built in July, 2016. I think @Homebodyatheart has the newer Norcold fridge. Hers is black and we have the light gray colored one. This is one of the mid model year changes nüCamp has been known to make.
Ikc001- known issue with the green indicator bulb burning out on the 180.3 series three way. I replaced mine within 1 year with an LED bulb. I will search for the post and repost once found.
‘18 Tab 320S- mfg’d 4/17, acquired 9/17 Spare & bike rack on tongue, Renogy 100w suitcase connection, cargo & door nets, sway bar, wired rear camera, Norcold aux fan, front window protection, frame mounted sewer & water hose storage, Krieger 1500w inverter w/100Ah LIFePO4. ‘24 Ford F150 XLT PowerBoost- 11,000# capacity ‘20 Honda Pilot Elite- 5000# tow cap, 500# tongue cap Huntington LI
So, I guess the answer depends on which model fridge we are talking about.
Huntington LI
Huntington LI
