TAB 400 door lock problem
13»
  • kbdigitiqe
    kbdigitiqe Member Posts: 163
    @p21usa is it obvious what do with this kit? I just ordered mine and I’m having a hard time following where the bolts and washers actually go ?? Here’s hoping 🤷‍♂️
  • p21usa
    p21usa Member Posts: 13
    It’s been a while but I recollect that the biggest issue was holding the washers in place while stacking them with the plates. We used a little spray adhesive. Wish I had more info but my husband did the actual work. I was just an extra set of hands.
  • Denny16
    Denny16 Member Posts: 5,430
    One could use carpet tape to hold the bits in alignment whilst installing them in place.
  • kbdigitiqe
    edited May 2021
    UPDATE: just did this fix in 10mins time. Went the hardware store, bought x4 5mm x 12mm bolts and x4 washers that fit them. The washers almost perfectly span the gaps between the bolts so it’s plenty stable.
    Highly recommend marking the screw locations first and then as others have said using some spray (or any kind of) adhesive- I just stuck the washers in place over the holes, put the assembly back over the and screwed the new bolts in.
    The lock functions perfectly now, just as one would expect.
    Ps - this is a brand new 2021 400 BD just took delivery a few months ago, it’s kind of shocking that NuCamp didn’t install a shim plate at the factory.. oh well
    Pic: you can see the washer behind the top screw
  • ncarbs
    ncarbs Member Posts: 10
    This is all so disturbing. My 2021 Solo has the same problem. Hasn't this issue gone on long enough, nuCamp? If I had a new car and something like this happened, knowing how much money we all have spent on these trailers, do you think the manufacturer would have let this go this long? This is a safety issue. Maybe there should be a class action law suit by the owners. I'm at the point where I tell people looking at teardrops to NOT BUY A nuCAMP. The one year warranty should apply to any new or used trailer as long as it's still under one year. These issues are a result of poor design, bad service, bad warranty and cheap parts right out of the gate.
  • Verna
    Verna Member Posts: 6,876
    @ncarbs, nüCamp RV does not read this forum. Please send all complaints to help@nucamprv.com.
  • RMo
    RMo Member Posts: 162
    Not that that excuses NuCamp for not fixing it, but I took a heavy duty screwdriver to bend the latch receiver out a few millimeters and I’ve had a secure lock for the last year.
    2019 T@B 400 (for sale)
    2017 Highlander Limited
  • dlb
    dlb Member Posts: 175
    The screwdriver approach worked for me.  Way easier than fussing with washers, adhesive and language I do not approve of….
    2021 Tab 400 Boondock
    2020 Audi SQ5
  • redaunt
    redaunt Member Posts: 31
    i know this is an old post……we just purchased a new (!!!!!) T@b 400 2023 model and door latch still has issues. I am surprised NuCamp has not developed a solution for this yet.
