400 ceiling Question
justdoit70
Member Posts: 56
2021 t@b 400 boondock solo . Looking at the ceiling just in front of the stargazer window to the first seam strip ,heading toward the front of the trailer, I noticed that the inner ceiling panel feels that the adhesive has failed and that section of inside material has come loose from whats above. If you push up in that area it is not the same ,it feels sticky under and there is movement.if you touch any where else on the ceiling it is solid has any one noticed this issue. All please check and report back if you can thanks.
Ed
Ed
All solid on my 2019 400.
2019 T@B 400 (for sale)
2017 Highlander Limited -
I don't see anything like you describe on the ceiling of our 2021 T@B 400.2021 T@B 400 BD, 2020 Toyota Tacoma Double Cab
SW Colorado -
Our 2021 400's ceiling has some give when I press on it but nothing to indicate its coming loose. I would recommend contacting your dealer and/or nuCamp to address the issue through them before starting any DIY work.
2021 T@B 400 BD, 2021 Lexus GX 460, Kansas City MO -
One thing you might try is injecting adhesive (like CA glue...super glue essentially) using a syringe. You can buy CA glue on amazon in a very liquid-like consistency and use a syringe to pierce the areas where the ceiling is breaking free and inject the glue. If the area is somewhat contained this should work.2021 400 BD
2020 Tacoma TRD Off-Road -
Thanks to all that checked their’s for me. No other 400’s out there?
Our 2021 400 ceiling seems just fine. Has a little give to it but does not have any indication of coming loose or separating.2021 T@b 400 BD "Vixen Gail"
Leadville Colorado -
@justdoit70, if you are looking to get it fixed, you do have a one year warranty from nuCamp. Please contact your dealer first. They will contact nuCamp for guidance from them. Please keep in touch with your dealer through this process.Verna, Columbus, IN
- 916 Introductions
- 72 Teardrop Groups & Links
