400 ceiling Question
justdoit70justdoit70 Member Posts: 55
edited June 2021 in Trailer & Towing
2021 t@b 400 boondock solo . Looking at the ceiling  just in front of the stargazer window to the first seam strip ,heading toward the front of the trailer, I noticed that the inner ceiling panel feels that the adhesive has failed and that section of inside material has come loose from whats above. If you push up in that area it is not the same ,it feels sticky under and there is movement.if you touch any where else on the ceiling it is solid has any one noticed this issue. All please check and report back if you can thanks.
Ed
