2021 t@b 400 boondock solo . Looking at the ceiling just in front of the stargazer window to the first seam strip ,heading toward the front of the trailer, I noticed that the inner ceiling panel feels that the adhesive has failed and that section of inside material has come loose from whats above. If you push up in that area it is not the same ,it feels sticky under and there is movement.if you touch any where else on the ceiling it is solid has any one noticed this issue. All please check and report back if you can thanks.
Ed
0 ·
2017 Highlander Limited Platinum
SW Colorado
2020 Tacoma TRD Off-Road
